pltIViewControl SwitchComplexPlots
Switches between the Real/Imaginary and Magnitude/Phase Complex plots.
hwIViewControl_handle SwitchComplexPlots
HyperWorks Tcl Modify
This command switches between the Real/Imaginary and Magnitude/Phase Complex plots. This differs from the SwapComplexPlots function in that it switches between the two different types of plot, rather than switching the position of the complex plot’s axes. This command will only work if in complex plot mode.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;;
w1 GetViewControlHandle vc;
vc SwitchComplexPlots;
plot Draw;
Returns success (0) or an error code.
Keywords
HyperWorks
XY plot
Tcl
Modify
