pltIViewControl Translation
Moves the axes up, down, left, or right based on the given string input.
hwIViewControl_handle Translation str
HyperWorks Tcl Modify
This command moves the axes in the plot based upon the input string. The curve in the plot appears as though it is moving, but in reality, it is the axis that is moving, changing the view. This differs from Translate in that you input a string with a preset amount to move, rather than an input amount for the axis to move.
- str
 - The str, or string, is an input which tells the function in which
            direction it should move. Each string moves the axes one unit in each direction stated.
            The different string options include:
- “up”
 - "down"
 - "left"
 - "right"
 - "upleft"
 - "upright"
 - "downleft"
 - "downright"
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc;
vc Translate "upright";
plot Draw;
If no string is input, an error message is displayed. If a string that is not one of the options is input, nothing happens. Otherwise, success (0) is returned and the plot changes.
Keywords
HyperWorks
XY plot
Tcl
Modify
