poITensorCtrl GetColor
Gets the color for a given tensor component.
poITensorCtrl_handle GetColor name
HyperView Tcl Query
This command retrieves the color for a given tensor component.
- name
 - The tensor component name. Options include: major, mid, minor, sxx, syy, or szz (1, 2, and 3 also accepted). Return value uses RGB format (for example, 255 255 255).
Returns the display mode, either drawreg or drawext (default).
