poITensorCtrl SetEnabled
Sets the dimension state, either enabled or disabled.
poITensorCtrl_handle SetEnabled pool state
HyperView Tcl Modify
This command sets the dimension state, either enabled or disabled.
- pool
 - The pool from which to set the enable state.
 - state
 - True if enabled, otherwise false.
Returns 0 if successful, otherwise an error code.
