poITensorCtrl SetShowValueMode
Sets the show value mode used for drawing tensor values in the graphics area.
tensor_handle SetShowValueMode mode_name state
HyperView Tcl Modify
This command sets the show value mode used for drawing tensor values in the graphics area. This command will control whether shear values, normal values, or all values of the tensor will be drawn.
- mode_name
 - The possible values are: all, normal, or shear.
 - state
 - The possible values are: true or false.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetTensorCtrlHandle tensor_handle
tensor_handle SetShowValueMode shear true
hwi CloseStackErrors
Returns a non-zero value if an error occurs.
