Convert Model File Solver Format
Convert model files from one solver format to another.
View new features for HyperWorks 2022.3.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Batch mode conversion is available for all solver interfaces.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
Setup an Optimization in HyperWorks.
ON THIS PAGE
Individual entities are listed in the browser, and color coded green, orange or red to highlight to which extent the card is converted to the targeted solver.
ON THIS PAGE
