HyperWorks
HyperWorks
2022.3
  1. Home
  2. Manage Files and Data
  3. Conversion Between Solver Formats
  4. OptiStruct Conversion
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.3
HyperWorks
  • What's New
    View new features for HyperWorks 2022.3.
  • Get Started
  • Tutorials
  • Tool Finder
    • Supported File Types
      The following file types can be read, depending upon the active application.
    • Create New Files
      Create a new file.
    • Open Files
      Open a file.
    • Import Files
      Import various file types into the selected client.
    • Warning Messages When Loading Files
      When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
    • Change Solver Interfaces
      Load a different solver interface in HyperWorks.
    • Conversion Between Solver Formats
      • Convert Model File Solver Format
        Convert model files from one solver format to another.
      • Batch Conversion Tools
        Batch mode conversion is available for all solver interfaces.
      • Abaqus Conversion
      • ADVC Conversion
      • ANSYS Conversion
      • LS-DYNA Conversion
      • Nastran Conversion
      • OptiStruct Conversion
        • OptiStruct to Abaqus Conversion Mapping
          The OptiStruct to Abaqus conversion uses an open conversion scheme; you can specify different mappings in the configuration file.
        • OptiStruct to ANSYS Conversion Mapping
        • OptiStruct to LS-DYNA Conversion Mapping
        • OptiStruct to Radioss Conversion Mapping
      • PAM-CRASH 2G Conversion
      • Permas Conversion
      • Radioss Conversion
      • Samcef Conversion
    • Load Files
      Load command files, scripts, solver template files, preferences, or the Metadata Table.
    • Save Files
      Save all of the data in your current session.
    • Export Files
      Export various file types from the selected client to another format.
    • Include Files
      Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
    • Take a Screen Capture
      Record a video or take a snapshot of the screen.
    • Convert Units
      Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
    Setup an Optimization in HyperWorks.
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.3
  1. Home
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
