Cosin Tire Graphics Tab
The Cosin Tire Graphics tab appears when an F-Tire property file is chosen. It defines the cosin tire’s graphic properties. A check box is available to produce and visualize the deformable tire graphics. The tire graphics are rendered by HyperView based on the node locations provided by Cosin.
![](../../images/post_processing/autotire_cosine_tire_graphics_tab.png)
Figure 1. Cosin Tire Graphics Tab
Reference Frame | The frame of reference for the graphics. Options are:
Circumferential Sections | Number of divisions along the circumference. |
Lateral Sections | Number of divisions along the tire width. |
Left Extreme | Beginning point of graphics on left side of tire. 0 indicates left rim flange. |
Right Extreme | Ending point of graphics on right side of tire. 1 indicates right rim flange. |
