Scooter - Double Side Trailing Link
![](../../images/post_processing/frnt_trlng_lnk_dble_swng_arm_susp.png)
Figure 1. Double Side Trailing Link Suspension with Steering
Model Use
- The wheel body represents the mass and inertia of the tire and the rim.
- The wheel hub body represents the mass and inertia of other rotating bodies such as a brake rotor. The wheel hub and brake rotor have no associated graphics.
- The wheel and wheel hub parts use the Wheel center location as the center of gravity.
The image below shows the Project browser view of the systems on a fully populated front suspension model. The Double Side Trailing Link Suspension system has six “child” systems.
![](../../images/post_processing/frnt_trlng_lnk_dble_swng_arm_susp_browser.png)
Figure 2. Browser View of Double Side Trailing Link Suspension
Points
![](../../images/post_processing/frnt_trlng_lnk_dble_swng_arm_susp_points.png)
Figure 3. Right Side Principal Points – Double Side Trailing Link Suspension
Bodies
![](../../images/post_processing/frnt_trlng_lnk_dble_swng_arm_susp_bodies.png)
Figure 4. Right Side Bodies – Double Side Trailing Link Suspension
Joints
Label | Type | Body 1 | Body 2 | Point | Notes |
Steering Swingarm Attachment Joint | Revolute | Swing Arm | Steering Column | Swingarm steering Att Point | |
Swingarm Spindle Att Joint | Fixed | Spindle | Swing Arm | Front Wheel CG | |
Spindle to Wheel | Revolute | Front Wheel | Spindle | Front Wheel CG | |
Steering REV Joint | Revolute | Handle | Frame | Steering Axis Top | |
Handle | Fixed | Handle | Steering Column | Steering Axis Top |
![](../../images/post_processing/frnt_trlng_lnk_dble_swng_arm_susp_bushings_jnts.png)
Figure 5. Joints - Double Side Trailing Link Suspension
