Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
Use the Result on Stack tool to display layer based shell results along with the real
stacking sequence of the selected element(s).
As the proper information of the stacking sequence of the
element is in the FE deck, you have to load the model (deck) in a HyperMesh client in the same session, so that the tool can access the
required information in the database.
Next, you have to contour the needed result in a
contour plot and then you can run the application.
Two options are available:
Quick Query
Append Multiple Results
Quick Query
With Quick Query, you can select one element only and will get a HyperGraph pop-up window showing the needed results. Figure 1. Figure 2.
With the option Append Multiple Results, you can select multiple elements and the tool will
append to the current session as many HyperGraph pages for as
many selected entities. Figure 3.
Will display: Figure 4. Figure 5.
The Result On Stack tool support the following solver profiles:
