Display State of Graphical Manipulators
Graphical manipulators are convenient for moving, changing orientations, and resizing entities where applicable.
- A manipulator is displayed every time a new entity (section cut, streamline/rake, image plane) is created. If a manipulator is already shown on the screen for another entity, the creation process will hide that manipulator and display the manipulator for the new entity.
 - The manipulator is automatically hidden every time the display of the entity to which it is attached is turned off.
 - Available in the Results Browser and also as a right-click menu option in the Section Cut panel and Streamlines panel. Displays the manipulator for the selected item.
 - If the individual item is not currently displayed, the manipulator and item are turned "on" using the Show Manipulator context menu option.
 - If a manipulator is displayed elsewhere, the context menu activation will hide the old item and make the current object and its selection the active one.
 - Once activated using the context menu, the manipulator display can be turned off by using the Hide Manipulator right-click context menu option or whenever a new entity (section cut, streamline/rake, or image plane) is created.
- Available in the Results Browser and also as a right-click menu option of Section Cut panel, Streamlines panel, and the Image Planes tab. Hides the manipulator for the selected item.
 - Available in the graphics area right-click context menu. Turns off the display of any manipulator that is currently active.
