View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Animation files are opened using the Load Model panel.
Use the Load Model tool to load model and result files.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the HyperView model structure while providing find, display, and editing control of entities.
Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes in Altair HyperWorks Desktop.
Entities can be selected using input collectors or the quick window selection method.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
