Table Selection
Once an operator is selected, tables must be selected to form the input.
![](../../images/post_processing/result_math_expression_builder_table_selection.png)
Figure 1. Expression Builder with the table selection section expanded to Show all
Once a table address is specified, it can be added to the expression (at the current insertion point that corresponds to the argument being defined) by clicking Insert. This will add a table address; however, it will be a short-hand form that allows long expressions to be authored without having to deal with long data type names.
LCnFn.{S|V|T}n.Cn.Ln
Where:
n
Index (load case index, frame index, table index, component index, and so
on)
LC
= Load case
F
= Frame (simulation
step)
{S|V|T}
= Scalar, Vector, Tensor
C
Component (valid only for vector or tensor tables).
L
= Layer
index
Table | Address | Reference |
T1.C1 | 1st tensor, 1st component | Stress, XX (scalar, two layers: Z1 & Z2) |
T2. | 2nd tensor | Strain (tensor, two layers: Z1 & Z2). |
T2.C3.L1 | 2nd tensor, 3rd component, 1st layer | Strain, ZZ, Z1 (scalar, no layers) |
V2 | 2nd vector | Rotation (vector) |
Table references can be made to resources only, and not to tables that are user-defined as a result of an expression. For example, if you define a new tensor, it cannot be addressed in an expression.
![](../../images/post_processing/result_math_expression_builder_table_selection_ex.png)
![](../../images/post_processing/result_math_expression_builder_table_selection_ex2.png)
Figure 3.
