Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and
minor strain output results of a forming simulation.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
You can create as many sets/groups as you want, and the same entity
can exist in multiple sets. All component/part (only) set types that are created
will be displayed in the entity list tree in the Entity Attributes panel and in the Results Browser (click the Sets drop-down menu to view
the groups and their components).
From the Create tools, select Create > Sets.
From the Set panel, click Add.
A set/group is added to the bottom of the Sets list.
Note: By default,
the newly added set is automatically labeled given a name and is assigned
the entity type currently selected on the input collector.
With the new set highlighted, change the input collector to the type of entity
you want to add to the set.
When a different type of set (group) is selected from the Sets list, the
entity type shown on the Selection input collector is updated to correspond with
the new set type that was chosen. Conversely, if the input collector type is
changed, the set type of the highlighted group will be converted to the new set
type that was chosen. For example, if the input collector of a component group
is switched from Components to Nodes, all the nodes of the original components
become the entities of the set. The set type is automatically updated, based on
the entity type that is selected using the Selection input collector.
Select entities using the input collector or pick directly from the
screen.
Under Action, turn on the Add option.
Click Add or Remove to toggle
the Add to Set/Remove from Set button between the two available options.
Click Add to Set.
The selected entities are added to the set and the number of entities in
the set is listed for reference.
Optional: Remove select entities from the set.
Under Action, turn on the Remove option.
Select the entities that you want to remove.
Click Remove from Set.
Optional: Redefine the entire set by clicking Clear.
All of the selected entities of the active set are cleared.
Note: Repeat
the steps above to select new entities for the set.
