Export a Line Definition File
To export the trimmed line definition file as a text file from the Tracing panel.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Use the Tracing tool to trace system, component, and node entities during animation.
