Access Upfront Data Loader
- To access the Upfront Data Loader on Windows, select
- From the Startup dialog, select HyperView and use the Profile drop-down menu to select the Upfront Loader profile.
- Click Create Session.
from the Start menu. - To access the Upfront Data Loader on Linux, run
hvxul
from the <install_dir>/altair/scripts directory.
This will set the proper environment to run the Upfront Data Loading infrastructure on HyperWorks.
