Change the Vector Color by Direction
From the Plot tools, click the Vector tool.
- From the Vector panel, click the Display tab (located in the middle of the panel).
Select Direction from the Color by drop-down menu.
The vector is displayed with the colors defined by the buttons. The buttons are enabled and the default colors for the vector are:
- Red for X
- Green for Y
- Blue for Z
- Yellow for resultant X+Y
- Light blue for shear resultant Y+Z
- Pink for shear resultant Z+X
- White for shear resultant X+Y+Z
Click the color box and select a different color from the color palette.
The colors for the components or resultant are changed.
