Flatten the Airbag
Use the Flatten tool to flatten the airbag.
Before performing a given fold, it may be better to flatten the airbag, like a real operator would do with a real airbag.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Use the Read Positions tool to read .h3d node positions.
Use the Stitching tool to attach the various patches by moving patches and merging boundary nodes.
Use the Create Table tool to create a table on which the airbag will be folded.
Use the Housing tool to fit the airbag to housing/container.
Use the Presimulation tool to convert the airbag to Radioss format and prepare it for the next folding steps.
