Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
This realization creates rows of HEXA elements for the body. The HEXA elements project
and connect to the adjoining shell/solid elements by touching them.
Note: Uses the
default parameters, material thickness lookup table, and material strength lookup
table from the weld_config.ini config file to set the default
attributes for the created MATL100 material.
The adhesive - shell gap exists in exactly the same configuration with the following
additional names:
HC glue mastic sealer
HC glue spot sealer
HC glue glass adhesive
This is in order to keep the realization names from HyperCrash.
The realization uses the prop_dyna_matnum_seamarea.tcl post
script. Figure 1.
