Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Stitch HL is a unique type of Connector as it can only be Absorbed as an Analysis type
Connector. It can be used to define a weld between 2D-2D, 2D-3D, and 3D-3D. These
Analysis Connectors cannot be Unrealised or Realised, only Updated. Figure 1.
It is intended for identifying Stitch welds within an existing model and creating sets to
define the Heat Affected Zones (HAZ), as well as define the details according to the
standard: EN 15085 3. Figure 2.
The HAZ is defined through a EL2MAT set of the Elements that lie within the tolerance. In
the situation where there are cross over welds, the weld connecting a Part with the
lowest Yield Stress will contain the elements. In the situation where there isn’t a
Yield Stress, or both are the same Material/Yield Stress, the longer of the Connectors
will then use the elements. Figure 3.
