Create and Edit Gaps
A gap element is an element created in a space between two nodes, or between a node and an element, of a model where contact may occur. Use a gap element when you want to impose a nonlinear constraint on a model; this constraint will limit the amount of movement possible during analysis.
From the Elements ribbon, click either the Gaps or Gaps 1D tool depending on the solver interface.
The Gaps panel opens.
For more information on creating and updating gaps, see either the Gaps Panel - HyperWorks or the Gaps Panel - OptiStruct topic.
