Create, Review, and Edit RBE2 Elements
Create RBE2s
RBE2 elements are commonly used to connect parts, apply fixed boundary conditions, and other places where a rigid connection is appropriate. RBE2s enforce rigid body behavior for the nodes and degrees of freedom of which they are comprised. This tool may be used to quickly create and modify RBE2s directly when the use of Connectors technology is not necessary/desired.
Review and Edit RBE2s
To open the RBE2 tool in edit mode, do one of the following from idle:
- Double-click on an RBE2.
- Select an RBE2, then select Edit from the right-click menu.
- Select an RBE2, then access the tool via the ribbon icon.
- Utilize any of the actions noted above to review or modify the RBE2 connectivity, DOF, and/or independent node location.
On the guide bar, click
to create another RBE2 or click
to exit the tool.
- Refer to the entity status icon on the guide bar for status and feedback. Clicking the icon will fit the view to the current RBE2.
- Changes made in the RBE tool are automatically committed to the database. If a change is made that invalidates the RBE (for example, clearing the dependent node selection), the RBE will turn grey and the database will not be updated until the RBE is made valid again. The entity status icon and error flags on the selectors help identify required inputs.
- Hold Ctrl (add) or Shift (remove) in to select individual nodes in quick succession. The RBE will be updated upon releasing Ctrl/Shift.
