HyperWorks
HyperWorks
2022.3
  1. Home
  2. Model Build and Assembly
  3. Manage Parts
  4. Manage Representations
  5. Reload Representations
    Restore part representations to their original state.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.3
HyperWorks
  • What's New
    View new features for HyperWorks 2022.3.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
    • Manage Parts
      • Open the Part Browser
        Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
      • About Parts, Part Assemblies, Part Instances
        A part is an engineering representation of a physical part, and a part assembly is a group of part assemblies and/or parts. Part Instances, which are recognized from PDM, are automatically converted to Part Instances on import into HyperMesh.
      • Create Parts, Part Assemblies, and Part Instances
        Only CAE parts and part assemblies can be manually created in HyperMesh. PDM parts and part assemblies must be imported into HyperMesh.
      • Import Parts, Part Assemblies, and Part Instances
      • Organize Part Assemblies and Parts
        Organize part assemblies, parts, and components in your model.
      • Transform Parts Assemblies and Parts
        Translate, rotate, reflect, scale, and position selected parts and part assemblies.
      • Save Assemblies as HyperMesh Binary Files
        The part assembly can be saved as a self-contained binary file, which will include the part assembly based hierarchy and attributes such as components, properties, and materials.
      • Manage Representations
        • About Representations
          The CAD representation is typically the original source of information of what a physical part will look like.
        • Create Representations
        • Define Representations
          Create your own user defined representation. User defined representations are saved to the settings and will be available in subsequent HyperMesh sessions.
        • Add Representations
          Part representations can be added from external sources such as solver decks and HyperMesh binary files or from the Part Library.
        • Browse Library Content
          Review library content using the Library Viewer.
        • Load Representations
          Part representations can be loaded from your current HyperMesh session or from the Part Library.
        • Reload Representations
        • Unload Representations
          Unload part representations from a session.
        • Update Metadata From PDM
        • Sync Metadata To PDM
          Sync PDM metadata (PDM PID, PDM Thickness, PDM Material, and PDM MID) based on a selected part or part's metadata (PID, Thickness, Material, MID).
        • Save Representations
          After importing a BOM and creating respective representations, you can save the representations locally or in the Part Library.
        • Delete Representations
          Part representations can be deleted from the current HyperMesh session and from the Part Library.
        • Representation Load Settings
          Settings to configure the representation entity management behavior.
      • Manage Part Revisions
        Manage, control and update Major, Study and Library Part revisions using the Part Library.
      • Manage Configurations
        Group common and unique parts/part assemblies together in part sets, and organize parts and part sets that are unique to a configuration.
      • PDM Live Connection
        Using PDM live connection, on-demand downloading of datasets from external PDM systems such as Teamcenter is possible
      • Teamcenter - HyperMesh Integration
        All BOM-related information, including part/assembly hierarchy, part attributes, and representation information is organized and displayed in the Part Browser.
    • Manage Subsystems
    • PostgreSQL Installation and Configuration
      Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
    • Section Library
      Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
    • Organize Entities
      Use the Organize tool to move or copy entities into their proper destinations.
    • Match Parts
      Automatically group selected parts into part sets based on comparison method and criteria selected.
    • Classify Parts
      Set up and use machine learning (ML) models to automatically classify parts under user-defined labels and into part sets.
    • Renumber Entities
      Use the Renumber tool to review and organize the IDs of model entities.
    • Reorder Entities
      Change the order of named entities in database.
    • ID-Management
      Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
    • Manage Scenarios
      Scenarios are a mechanism to apply controls to engineering entities.
    • Mechanism Browser
      Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
    • Model Verification
    • Systems
      Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
    • Create Vectors
      Define vectors in 3D space.
    • Assign Properties and Materials
      Define physical and mathematical characteristics of parts.
    • Generate Contacts Automatically
      Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
    • RBE2s, RBE3s, and MPCs
      Create, review, and edit RBE2/RBE3 elements and MPC equations.
    • Create and Edit Curves
      Use the curve editor to create and plot XY curves.
    • Analytical Rigid Surfaces
      The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
    Setup an Optimization in HyperWorks.
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.3
  1. Home
  3. Manage Parts
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
In the Part Browser, right-click on parts or part assemblies and select Representation > Reload from the context menu.
Representations are reloaded from the repository.
