Configuration Options
Options
- Auto-fit
 - Automatically fit the selected items to the modeling window, whether using the context menu, Show/Hide, or Isolate functionality to control the display.
 - Auto-scroll on selection
 - Locate/highlight an item in the browser and automatically adjust the
                            browser tree to display the item upon selection. This functionality is
                            only available when an item has been selected in the modeling window.
If this option is not activated, then the item will still be located/highlighted in the browser; however, the browser tree will not automatically adjust to show the selected item.
Entities
Select/change the entity types that are displayed in the Results Browser.
Toolbars
- Change loadcase
 - The Change loadcase toolbar allows you to change the current load case/simulation.
 - Change model
 - The Change model toolbar allows you to change the current model.
 - Find/Filter
 - The Find/Filter toolbar contains search options that can be used to locate an entity within the browser's tree structure.
