Edit Solver Specific Data (Template Data)
Every entity is assigned solver specific data, which you can modify using the Entity Editor.
Assign a Card Image
In the Entity Editor, you can assign a card image to an entity. The card images you are able to assign depend on the user profile you have loaded and the entity type you have selected in the browser.
Import and Export Data
- Import from file
- Append from file
- Export to file
- Import and export functions are not available for 2D arrays or a combination
of 1D and 2D arrays, as in the case of Abaqus.
Figure 1. Density Info for ABAQUS_MATERIAL - Certain control cards make use of unstructured tables. In these cases, array
attributes are shown as new categories/columns and data cannot be
imported/exported.
Turn Fields ON or OFF
Assign Entities
In the Entity Editor you can assign certain entities to another entity or a group of entities.
For example, you can assign a property to a component. When an entity has an entity assigned to it, the name and ID of the assigned entity will be displayed in the Value field. If an entity does not have an entity assigned to it, the Value field will display <Unspecified>.
![](../../images/entity_selection_ee_unity.png)
Figure 12.
If available, you can expand a drop down menu on the entity selector to view more entity types.
Select entities to assign in the following ways:
- Click
, press ".", or press Ctrl + Spacebar to select by typing names or IDs. While typing, the selection search function provides live suggestions of:
- Entity names that contain the typed search terms (separated by
space) somewhere in their name.Tip: If you wish to treat spaces as characters instead of search term separators, turn on the Match Exact Phrase option in the Preferences dialog, located in .
- Entity IDs that begin with a numeric search term.
A live suggestions list will show partial matches for names and IDs while typing, up to a certain number (configurable in Browse More, or press Ctrl + Enter, to browse and select from the full partial match list.). If the model contains more partial matches than listed in the suggestions list, clickTip: Live partial match suggestions are available for entity counts of up to 100,000. However, you can still select by typing names or IDs regardless of model size, and full match suggestions will be still provided and selectable. - Entity names that contain the typed search terms (separated by
- Click
to open the Advanced Selection dialog. Select entities then click OK.
- Select entities in the modeling window.
If the Advanced Selection dialog is open, the corresponding entity is automatically selected in the dialog.
- Click
To confirm your selection and assign the entity, click
To clear your selection or unassign an entity, click
To exit the entity assignment tool, click
Resolve Unresolved Entities
![](../../images/ee_unresolved_unity.png)
Figure 13.
Right-click on an unresolved entity, or click
, then select Clear unresolved entity from the context menu.
- Click the entity's Value field.
- Use the entity selector to choose a new entity.
Keyboard Shortcuts
Function Key | Description |
Tab | Moves from one row to the next in the Entity Editor. |
Shift + Tab | Moves to the previous row in the Entity Editor. |
Spacebar | Activates the Value field of the selected row. |
Move up and down in the Entity Editor, a list of options in drop-down menus, or in a right-click context menu. |
Enter | Accepts the changes made to a parameter in the Value field, or selects an option in a right-click context menu. |
Esc | Dismisses the changes made to a parameter in the Value field, or closes a right-click context menu. |
