Modify Link State
The link state defines if the weld created during connector realization connects to geometry or mesh on the link.
This is applicable to only components and surfaces entities that can contain geometry and/or mesh information.
View new features for HyperWorks 2022.3.
Use the Connector Browser to view and modify connectors in the current model.
The Link Entity Browser displays all of the links that are connected using the connectors in the model.
The Connector Entity Browser contains a list of all the connections contained in the model, and has its own set of tools similar to the ones found in the Link Entity Browser.
Use the Connector Entity Editor to quickly view and modify attributes assigned to connector(s).
A link is a reference to a separate entity. One or more links are added to a connector. The entities to which the links refer are connected during realization.
Convert connectors of one specific style into a different style, for example a spot connector into a bolt connector using the Convert option.
Combine aligned single point connectors into line connectors or combine several aligned seam line connectors into larger one(s) using the Combine option.
Split spot or bolt line connectors into individual single point connectors using the Split option.
Place a connector in-between the center of the two farthest defined links or its source position using the Position option.
Add links (component, assembly, surface, element, tag, node) at a time to one or more connectors using the Add Link option.
Remove links from one or more connectors at a time.
Update the attributes associated with a link, such as reconnection rule, link references, and link state.
The link rule defines how a connector treats an entity added as a link.
Update links for the purpose of part replacement (link reference).
Existing connector links can be converted to one of the following link types: Part, Comp, or Prop. Connector link conversion requests a clear 1:1 relation between a component and a property, otherwise the conversion is not unique and will not be performed.
The find parts feature in the Connector Browser context menu finds the entities/part(s) connected by specific connector(s), and isolates them in the graphics area.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Use the Quality controller to perform various checks on connectors and realized FE.
Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
View details for different types of realizations.
Organize elements into connector groups.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Use the Connector tools to further define connections between components.
Abstract information incoming from the CAD hierarchy to robustly create connectors.
Setup an Optimization in HyperWorks.
