Properties
Figure 2. Create Properties Entity Editor
- Name
- Enter a unique name.
- ID
- Enter a unique ID.
- Card Image
- A predefined type which describes the general form of the element that
the property can be applied to. The property type is chosen from the
Card Image drop-down menu.Note: The property type determines the property parameters so the Input button remains inactive until a property type is selected.
- Material
- Assign material models to the property. The number of materials required depends on the element cross-section. For example, a layered cross-section can contain up to four materials. In these cases, you must enter a material in the first data cell. A material may be chosen from the drop-down menus located in the material field. These lists contain all predefined models which apply to the current property type.
- Type
- Options based on the Card Image type selected.
