MARKER_READ
ModelingInputs a user-defined marker element.
Use
<Reference_Marker
id = "30102040"
label = "Joint 3-Marker I"
body_id = "30102"
body_type = "RigidBody"
usrsub_param_string = "USER(1,-0.5, 0.3, 0., 1.57079633, 1.57079633, -1.57079633)"
usrsub_dll_name = "NULL"
usrsub_fnc_name = "MARKER_READ"
/>Format
- Fortran Calling Syntax
SUBROUTINE MARKER_READ (ID, PAR, NPAR, ERRFLG) - C/C++ Calling Syntax
void STDCALL MARKER_READ (int *id, double *par, int *npar, int *errflg) - Python Calling Syntax
def MARKER_READ(id, par, npar): return function errflg = MARKER_READ(id, par, npar) - MATLAB Calling Syntax
Attributes
- ID
- [integer]
- PAR
- [double precision]
- NPAR
- [integer]
- ERRFLAG
- [integer]
eflg = 0
errflg = 0
r = 3 *[0.0]
angle = 6*[0.0]
angle_type = int(par[0])
r[0] = par[1]
r[1] = par[2]
r[2] = par[3]
if angle_type==0: # DCMTX
angle[0] = par[4]
angle[1] = par[5]
angle[2] = par[6]
angle[3] = par[7]
angle[4] = par[8]
angle[5] = par[9]
elif (angle_type == 1) | (angle_type == 2):# Euler angles (313 or YPR)
angle[0] = par[4]
angle[1] = par[5]
angle[2] = par[6]
elif angle_type == 3: # Euler parameters
angle[0] = par[4]
angle[1] = par[5]
angle[2] = par[6]
angle[3] = par[7]
else:
errflg = 1;
return errflg
eflg = py_put_marker(id, r, angle_type, angle)
return errflgComments
- MARKER_READ can only be defined in a Reference_Marker element. The MARKER_READ function is called only once during solver initialization to get the marker position and orientation for the analysis. MARKER_READ works similar to SPLINE_READ.
