SLA Suspension Example
This example, referred to as MV3010 in this section, describes the optimization of an SLA suspension and is also available in MotionSolve tutorial MV-3010: Optimization using MotionView - HyperStudy.
- The design objective
- Design a suspension such that the toe vs. ride height curve matches a target
curve shown in red in the image below.
Figure 2. - The design variables
- The Y- and Z-coordinates of the inner tie-rod ball joint and the outer tie-rod ball joint. There are four DVs and their design limits are specified as follows:
- The constraints
- There are no optimization constraints for this example.
