PTSF
Model ElementDefines a point-to-surface constraint element.
PTSF/1, I=30103030, JFLOAT=30103032, RM=30102010, SURFACE = 555
PTSF/id, I = id, JFLOAT = id, SURFACE = id, RM = id
[, DISP = x, y, z [,ICM=id] ]
Arguments
ID
ID of the curve.
I
ID of the marker whose origin is constrained to lie on the surface.
ICM
ID of the marker used as reference for defining DISP.
ID
Element identification number (integer>0).
JFLOAT
ID of the J floating marker on the body containing the surface. It is always positioned at point of contact and oriented such that the z-axis is normal to the surface.
RM
ID of the marker used to define the surface. This marker is fixed on the body containing the surface.
SURFACE
ID of the surface.
