Model ElementThe
Triamesh element allows you to represent a geometric figure using a
series of nodes and faces.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| rm |
Reference (Marker) |
No |
No |
| nodes |
Double (count=0) |
| faces |
Int
(count=0) |
| refinement_level |
Int
| material_inside |
Bool
| color |
String() |
| hidden |
Bool() |
Usage
nodes = [[0,0,0],[1,1,1],[-1,1,1]]
faces = [[0,1,2]]
Triamesh(rm=rm,nodes=nodes,faces=faces)
Attributes
- rm
- Reference(Marker)
- The marker is used as a coordinate system for the triamesh graphic.
- nodes
- Int()
- The list of nodes that define the Triamesh.
- faces
- Int()
- List of faces that define the Triamesh.
- refinement_level
- Int()
- Specifies the level of detail of the sphere entity. Default is 10.
- coils
- Int()
- Specifies the number of coils to represent the Spring
graphic.
- material_inside
- Bool()
- Specifies if the graphic has material inside or outside.
material_inside is a boolean flag
(True/False).
- True means the geometry is solid. In other words, it is
filled with material and its exterior is devoid of material. Consequently,
the surface normals of the geometry point outward.
- False means the converse: The exterior of the geometry is
filled with material and the interior is devoid of material. In this case,
the surface normals of the geometry point inward.
- color
- String()
- The color of the graphic for H3D animation. Specified as RGB (Red : Green :
Blue).
- hidden
- Boolean
- Specifies weather the graphics is being written to the H3D file or not.
- True implies that the graphic is hidden and is not
written to the H3D file.
- False implies that the graphic is not hidden and is
- This attribute is optional. When not specified, it defaults to
False.
- See Properties for an explanation about what properties are, why they
are used, and how you can extend these.
