/ANIM/BRICK/TENS
Engine Keyword Generates animation files containing tensor data (mean value or value in specified integration point) for brick elements, in global coordinate system.
/ANIM/BRICK/TENS/Keyword4/Keyword5
Definition
Keyword4 |
Keyword5 |
- Strain tensor is output only if Istrain =1 in /PROP/TYPE14 (SOLID); except for material laws 14, 24 and material laws greater than 28 (in these cases strain tensor is output irrespective of Istrain value).
- If
Keyword5=0 or blank:
- Stress tensor is output in the global coordinate system, irrespective of solid element formulation
- Strain tensor is output in the global coordinate system
- The "SPH outputs tensor" are available with Keyword4=STRESS
- If
Keyword5=ijk or ALL:
- If the integration point ijk does not exist in a solid, stress/strain tensor
is then set to 0.
For example:
For a one integration point 8 nodes solid, stress/strain tensor for integration point 112 is set to 0. Only stress/strain tensor for integration point 111 can have non-null components.
- If the integration point ijk does exist in a solid, stress/strain tensor
could output using Keyword5=ijk.
For example in one 8 nodes solid (with integration points 2x2x2):
Using /ANIM/BRICK/TENS/STRESS/121 to output stress in integration point i=1,j=2,k=1
Figure 1. - When Isolid =15 is used in /PROP/TYPE20 (TSHELL), /PROP/TYPE21 (TSH_ORTH), or /PROP/TYPE22 (TSH_COMP), the syntax becomes:
/ANIM/BRICK/TENS/STRESS/1j1 for stress
/ANIM/BRICK/TENS/STRAIN/1j1 for strain
- When
in /PROP/TYPE22 (TSH_COMP), the syntax
becomes:
/ANIM/BRICK/TENS/STRESS/i0k/j
/ANIM/BRICK/TENS/STRESS/101/j, if Isolid =15
/ANIM/BRICK/TENS/STRAIN/i0k/j
/ANIM/BRICK/TENS/STRAIN/101/j, if Isolid =15
is then set to 0.
