Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword Generates animation files containing damage value as function of a solid element integration point. The damage value
is the maximum of damage over time and of all failure criteria acting in one material.
Engine Keyword Generates animation output for the time at which a solid element is deleted. The rupture time is output only for elements
which are deleted, due to a /FAIL criterion. Failure criteria built in materials are ignored.
Engine Keyword Generates animation files containing tensor data (mean value or value in specified integration point) for brick elements,
in global coordinate system.
Engine Keyword Generates animation files containing a damage variable value as the function of a brick element. These output variables
are only compatible with failure model /FAIL/SNCONNECT.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
etc.) in state file (STA-File).
/ANIM/BRICK/Restype Engine Keyword Generates animation files containing brick element data for the specified result. Options used for BRICK element type.
/ANIM/BRICK/DAMA Engine Keyword Generates animation files containing damage value as function of a solid element integration point. The damage value is the maximum of damage over time and of all failure criteria acting in one material.
/ANIM/BRICK/TDEL Engine Keyword Generates animation output for the time at which a solid element is deleted. The rupture time is output only for elements which are deleted, due to a /FAIL criterion. Failure criteria built in materials are ignored.
/ANIM/BRICK/TENS Engine Keyword Generates animation files containing tensor data (mean value or value in specified integration point) for brick elements, in global coordinate system.
/ANIM/BRICK/TENS/DAMA Engine Keyword Generates animation files containing tensor data for brick elements.
/ANIM/BRICK/VDAMi Engine Keyword Generates animation files containing a damage variable value as the function of a brick element. These output variables are only compatible with failure model /FAIL/SNCONNECT.
/ANIM/Eltyp/TDET Engine Keyword Generates animation files to output detonation times in animations for the specified element type.
