/ANIM/DT
Engine Keyword Write animation files (A-files) at a time frequency equal to Tfreq, the first file being written at time Tstart. The animation file name will be RunnameAnnn where Runname is the Run Name and nnn is the file number.
/ANIM/DT
Tstart Tfreq
Definition
Tstart | Start time for writing the animation files | |
Tfreq | Frequency for writing the animation files |
