Engine Keyword Generates animation files containing shell
element data for the specified result. Options used for SHELL type of element.
/ANIM/Eltyp/Restype/Keyword4
Definition
Field |
Contents |
SI Unit Example |
Eltyp |
Element type.
- ELEM
- SHELL
- Shell elements
Restype |
- AMS
- Elements using AMS timestep due to /DT/CST_AMS.
- DAM1, DAM2 or
DAM3
- Damage in direction 1, 2 or 3 6
7
- /DAMG/Keyword4
- Damage value (only for coupled damage model). 11
- Keyword4 = MEAN (Default)
- Mean damage over thickness integration
points.
- Keyword4 = i
- Damage at the ith integration point
in the thickness.
- Keyword4 = UPPER
- Damage at upper integration point in the
thickness.
- Keyword4 = LOWER
- Damage at lower integration point in the
thickness.
- Keyword4 = MEMB
- Damage at the membrane.
- DENS
- Density
- DT
- Element time step. 10
- EINT
- Element internal energy.
- ENER
- Specific energy (internal energy divided by the element
mass).
- EPSD
- Equivalent strain rate in bricks and also in shells
(only available in case of strain rate filtering).
- EPSP
- Plastic strain
- ERROR/THICK
- Estimated error on shell thickness
- FAIL
- Number of failed layers for /PROP/TYPE10 (SH_COMP), /PROP/TYPE11 (SH_SANDW), /PROP/TYPE17 (STACK), /PROP/TYPE51, PCOMPP, /MAT/LAW15 (CHANG) and /MAT/LAW25 (COMPSH).
- For the other property sets and material laws the values
are:
- = 0
- If the element is not broken.
- = 1
- If the element is broken (only available in
case shell element:
/ANIM/SHELL/FAIL).
- HOURG
- Hourglass energy
- /NL_EPSD/Keyword4
- Non-local plastic strain rate (only if
/NONLOCAL/MAT is activated).
12
- Keyword4 = i
- Non-local plastic strain rate at the
ith integration point in
thickness.
- Keyword4 = UPPER
- Non-local plastic strain rate at upper
integration point in thickness.
- Keyword4 = LOWER
- Non-local plastic strain rate at lower
- Keyword4 = ALL
- Non-local plastic strain rate at all
integration points.
- /NL_EPSP/Keyword4
- Non-local plastic strain (only if
12
- Keyword4 = i
- Non-local plastic strain at the ith
- Keyword4 = UPPER
- Non-local plastic strain at upper integration
point in thickness.
- Keyword4 = LOWER
- Non-local plastic strain at lower integration
point in thickness.
- Keyword4 = ALL
- Non-local plastic strain at all integration
points.
- OFF
- Element status.
- Where,
- = -1
- Element is not active (it is defined in an
activated rigid body).
- = 0
- Deleted element.
- Between 0 and
1
- Under failure process.
- = 1
- Active element.
- P
- Pressure
- PHI/N or PHI/ALL
- Angle between element skew and direction 1 of
orthotropy. PHI is only valid for /PROP/TYPE11 (SH_SANDW) and
/PROP/TYPE16 (SH_FABR).
- = N
- Output angle in integration point
N (through shell thickness.
- = ALL
- Output angle in all integration points through
shell thickness.
- PLY
- If the plyxfem option is activated, each layer is
modeled as a shell element.
- SIGEQ
- Equivalent stress, based on the yield criteria used for
the corresponding material. 4
- SIGX
- Stress XX 8
9
- SIGY
- Stress YY
- SIGZ
- Stress ZZ
- SIGXY
- Shear stress XY
- SIGYZ
- Shear stress YZ
- SIGZX
- Shear stress ZX
- TEMP
- Temperature
- THIC
- Thickness
- THIN
- % thinning of shell
- TSAIWU/Keyword4
- Tsai Wu criterion for /MAT/LAW15
(COMPSH).
- Keyword4 = ALL
- Tsai Wu criterion of all integration
points.
- Keyword4 = LOWER
- Tsai Wu criterion at lower integration
point.
- Keyword4 = UPPER
- Tsai Wu criterion at upper integration
point.
- USRi
- Variable of user law (
=1 to 18).
- USRII or USRII/JJ
- Variable of user law on each integration points (II =1
to 99 number of the variable, JJ =1 to 99 number of
layer). 1
Tip: Since
the number of user variables that can be output is
limited, use /H3D/SHELL/USER/
instead.
- VONM
- von Mises stress
- /WPLA/Keyword4
- Plastic work for /MAT/LAW15 (CHANG)
- Keyword4 = ALL
- Plastic work of all integration points.
- Keyword4 = UPPER
- Plastic work at upper integration point.
- Keyword4 = LOW
- ER
- Plastic work at lower integration point.
- User variables USRII are available for shell and brick
elements, but USRII/JJ is only available for shell elements. When
an integration point is not explicitly described, returned integration point means
the integration point is superior; computed as [(number of integration points in
thickness + 1) / 2]. The result is then rounded up to the superior value.
- Example:
For two integration points in thickness, second integration point
from bottom (top of thickness) is returned.
For three integration
points in thickness, second integration point from bottom (middle one)
is returned.
For four integration points in thickness, third
integration point from bottom is returned.
- THIN is computed as:
(1)
- With ERROR/THICK, an estimated error on shells and 3-node
shells thickness is computed as:
- Nodal thickness is computed as:(2)
Where,
and
are the area and thickness of element
containing node
Then the thickness error is
evaluated for each element
, using the formula:
(3)
- The option
SIGEQ is available for SHELL and BRICK (refer to
/ANIM/BRICK/SIGEQ). Each material law, in Radioss has its own yield criterion to calculate the
equivalent stress. For some it is von Mises; for others, it is Hill or Barlat or
something else. For any non-von Mises criterion, the corresponded equivalent stress
(or criterion) is computed within all the integration points of the element.
Therefore, the output field /ANIM/SHELL/SIGEQ is computed as a
mean value over the all integration points (through all layers).
- The option
PLY is only available for SHELL. In this case, composite
shells are modeled according to the plyxfem formulation or
modeled with one shell/ply. Each generated shell is offset from the original
shell in its true position.
Note: The size of the animation files may
be highly increased.
- For shell and 3-node shell elements,
/ANIM/ELEM/DAM1, DAM2, and
DAM3, are available for material LAW15 and LAW25. These
values are the principal values of the damage (values in the local orthotropic
skew).
- The "SPH outputs" are available with
/ANIM/Eltyp =
ELEM/Restype (all
Restype values; except Restype =
THIC or HOURG). The
Restype values: DAM1,
DAM2 or DAM3 are only available with
material LAW24 for brick element.
- The option
/ANIM/ELEM/SIGX is only applied for shell elements. For brick
elements, /ANIM/BRICK/TENS must be used.
- In
/ANIM/ELEM/SIGX and /ANIM/ELEM/SIGY, shell
stress is located on the center of the element.
- Element time step is only displayed in
the animation if Radioss has computed an elementary
time step this element. If nodal time step is used (for example,
/DT/NODA), element time step is not displayed in the
animation.
- Option
DAMG is only used with coupled damage models
(/MAT/LAW72 or /FAIL/GURSON) to output
damage over integration points. The damage variable is normalized by its
critical value.
- For /MAT/LAW72(4)
- For /FAIL/GURSON(5)
- If /NONLOCAL/MAT option is activated, it is possible to
output the regularized non-local plastic strain and its rate.
- In cases where /ANIM/SHELL is used to output data on
QUAD elements, /ANIM/SHELL/EPSP can be used to plot plastic
work for composite material laws (/MAT/LAW15 and
/MAT/LAW25), or plastic strain for all other
elastoplastic material laws.
