/DFS/DETPLAN/NODE
Block Format Keyword Describes a planar detonation wave.
![dfs_detplan_image](../../../images/solvers/dfs_detplan_image.png)
/DFS/DETPLAN/NODE/detp_ID/unit_ID | |||||||||
TDET | mat_ID | P_ID | |||||||
N_ID |
Definition
detp_ID | Detonator identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
P_ID | Node identifier for base point
P. Default node P is (0, 0, 0) (Integer) |
TDET | Detonation time. Default = 0.0 (Real) |
mat_ID | Explosive material number concerned by
detonation time.
(Integer) |
N_ID | Node identifier for normal vector
definition. (Integer) |
- Detonation time is TDET in plane containing basis point P.
- It is possible to define multiple detonators with different types and lighting times.
- If a detonation option is not defined, all JWL material law will instantaneously detonate.
- Burn fractions are available in time history file with /TH/BRIC card and BFRAC keyword.
- Detonation times can be written in the Starter output file for each JWL elements. Printout flag IPRI ≥ 3 (/IOFLAG).
