Generation of Tangential Force
![](../../../images/solvers/guide_tang-force.png)
Figure 1. Generation of Tangential Force
- It is always advised to post-process the contact forces. If they are too large, taking into account the physical understanding, the model must be checked.
- To post-process the forces
for symmetric contact, the interface can be split into four interfaces. For example,
for two parts A and B, you can create:
- Interface 1 with A Secondary and B Main
- +Interface 2 with A Main and B Secondary
- +Interface 3 with A Main and Secondary
- +Interface 4 with B Main and Secondary
