/INIV/AXIS/Keyword3/2
Engine Keyword Initialize rotational velocity about an axis and translational velocity on a node set.
Frame_ID
VXt VYt VZt Vr
grnd_ID
Definition
Field Contents Si Unit Example
Keyword3 Direction X, Y, and Z of the frame defining the rotation axis.
Frame_ID Frame identifier.
(Integer)
VXt , VYt , VZt Translational velocity components in the local frame.
(Real)
[ms] MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaadaWcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Vr Rotational velocity about the axis Keyword3 in the local frame.
(Real)
[rads]
grnd_ID Node group (/GRNOD) or node set (/SET) on which specific initial velocities are applied.
  1. If frame_ID is not zero, the initial velocities are applied with respect to this local frame.
  2. Once Vt MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbba9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0FirpepesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcbaGaaCOvamaaCaaaleqabaGaamiDaaaaaaa@3BDB@ is expressed in the global system, the velocities are initialized with respect to:(1)
    v(M)=Vt+VrUUΛOM MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbba9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0FirpepesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcbaGaaCODaiaacIcacaWGnbGaaiykaiabg2da9iaahAfadaahaaWcbeqaaiaadshaaaGccqGHRaWkcaWGwbWaaWbaaSqabeaacaWGYbaaaOWaaSaaaeaacaWHvbaabaWaauWaceaacaWHvbaacaGLjWUaayPcSdaaaiabfU5amjaah+eacaWHnbaaaa@4B18@
    Where,
    U MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbba9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0FirpepesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcbaGaaCyvaaaa@3AB4@
    Vector defining the rotation axis
    O MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbba9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0FirpepesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcbaGaaC4taaaa@3AAE@
    Represents a point on the axis and is set as the origin of the frame.
