Iform = 12
Block Format Keyword Up to 4 different sub-materials (solid, liquid, gas and explosives) can be defined by specifying a material identifier and initial volume fraction.
- LAW3 (HYDPLA)
- LAW4 (HYD_JCOOK)
- LAW5 (JWL)
- LAW6 (HYDRO)
- LAW10 (DPRAG1)
- LAW102 (DPRAG2)
- /EOS/LINEAR
- /EOS/POLYNOMIAL
- /EOS/IDEAL-GAS
- /EOS/STIFF-GAS
/MAT/LAW51/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
Blank | |||||||||
Iform |
νν |
mat_ID1 | αmat _ 10αmat_10 |
mat_ID2 | αmat _ 20αmat_20 | ||||||||
mat_ID3 | αmat _ 30αmat_30 | ||||||||
mat_ID4 | αmat _ 40αmat_40 |
Definition
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
title. (Character, maximum 100 characters) |
Iform | Formulation flag =
12. (Integer) |
νν | Kinematic viscosity in
shear
ν=μ/ρν=μ/ρ
. 4 Default is computed from sub-material laws (Real) |
[m2s][m2s] |
mat_ID1 | Material identifier for
the 1st sub-material which must refer to LAW3, 4, 5, 6,
10, or 102. Mandatory (Integer) |
αmat _10αmat_10 | Initial volumetric
fraction for the 1st sub-material. Default = 0 (Real) |
mat_IDi | (Optional) Material
Identifier from 2nd to 4th sub-material which
must refer to LAW3, 4, 5, 6, 10 or 102. Default = 0 (Integer) |
αmat _i0αmat_i0 | (Optional) Initial
volumetric fraction. (Real) |
▸Example (2 Submaterials)
- The material law is based on a diffusive interface technique. Numerical diffusion can be improved using MUSCL method for volume fraction (/ALE/MUSCL). The previous /UPWIND method for limiting diffusion is now obsolete.
- The sub-materials can be listed in any order, but only one of them can be an explosive sub-material /MAT/LAW5.
- If 4 sub-materials are requested, at least one of them should be an explosive sub-material /MAT/LAW5.
- Kinematic
viscosities are global and are not specific to each material. They are used to
compute the viscous stress tensor:
(1) τ=μ[(∇⊗V)+ t(∇⊗V)]+λ(∇V)Iτ=μ[(∇⊗V)+t(∇⊗V)]+λ(∇V)IWhere,- ν=μ/ρν=μ/ρ
- Kinematic viscosity in shear.
- μμ
- Automatically computed from mixture sub-material definition (LAW6): µ=Nsubmat∑i=1αiµi
- λ
- Calculated such as 3λ+2μ=0 (Stokes hypothesis).
- Volumetric
fractions enable the sharing of elementary volume within the three different
materials.
For each material αmat _ i0 must be defined between 0 and 1.
Sum of initial volumetric fractions ∑3i=1αmat_i0 must be equal to 1.
For automatic initial fraction of the volume, refer to the /INIVOL card.
- It is not recommended to use this law with Radioss single precision engine.
