Failure Models
The supported failure models in Radioss.
Failure Model Description
Failure Model Keyword | Type | Application | Description |
/FAIL/ALTER | Stress-based for glass | Glass | Stress-based for glass |
/FAIL/BIQUAD | Strain failure model | Ductile metal | Direct input for effective plastic strain to failure |
/FAIL/CHANG | Chang-Chang model | Composite | Failure criteria for composites |
/FAIL/COCKCROFT | Ductile failure model | Ductile material | Cockcroft-Latham failure model |
/FAIL/CONNECT | Failure | Connection, spotweld | Normal and tangential failure model |
/FAIL/EMC | Extended Mohr Coulomb model | Metal | Failure dependent on effective plastic strain |
/FAIL/ENERGY | Energy isotrop | Metal, plastic | Energy density |
/FAIL/FABRIC | Traction | Fabric | Strain failure |
/FAIL/FLD | Forming limit diagram | Metal Forming | Fld |
/FAIL/GENE1 | Failure | Multiple failure model with multiple combinations | |
/FAIL/GURSON | Ductile failure model | Metal | Failure based on void nucleation and growth in metal plasticity |
/FAIL/HASHIN | Composite model | Composite | Hashin model |
/FAIL/HC_DSSE | Extended Mohr Coulomb failure model | Metal | Strain-based Ductile Failure Model: Hosford-Coulomb with Domain of Shell-to-Solid Equivalence |
/FAIL/INIEVO | Initiation/Evolution failure model | Ductile material | Two steps initiation + evolution damage criterion coupled with stresses computation |
/FAIL/JOHNSON | Ductile failure model | Ductile metal | Johnson-Cook |
/FAIL/LAD_DAMA | Composite delamination | Composite | Ladeveze delamination model |
/FAIL/MULLINS_OR | Hyperelastic damage | Hyperelastic materials | Stress softening Mullins effect of hyperelastic materials |
/FAIL/NXT | NXT failure model | Metal forming | Similar to FLD, but based on stresses |
/FAIL/ORTHBIQUAD | Orthotropic strain failure model | Ductile metal | Direct input for orthotropic effective plastic strain to failure |
/FAIL/ORTHSTRAIN | Orthotropic strain failure | Composite | Orthotropic strain failure criteria with size effects and strain rate effects |
/FAIL/PUCK | Composite model | Composite | Puck model |
/FAIL/RTCL | Ductile failure model | Ductile metal | RTCL (Rice – Tracey – Cockroft – Latham) failure model |
/FAIL/SAHRAEI | Battery model | Battery cells | Orthotropic strain-based failure model to predict failure and shortcut in battery cells |
/FAIL/SNCONNECT | Failure | Connection, spot weld | Failure criteria for plastic strain |
/FAIL/SPALLING | Ductile + Spalling | Ductile metal | Spalling + Johnson-Cook |
/FAIL/SYAZWAN | Ductile failure | Ductile metal | Stress triaxiality-based ductile failure model |
/FAIL/TAB1 | Strain failure model | Ductile metal | Based on damage accumulation using user-defined functions |
/FAIL/TAB2 | Strain failure model | Ductile metal | Based on damage accumulation using user-defined functions |
/FAIL/TBUTCHER | Tuler-Butcher model | Ductile metal | Failure due to fatigue |
/FAIL/TENSSTRAIN | Traction | Metal, plastic | Strain failure |
USER1,USER2, USER3 | User failure model | ||
/FAIL/VISUAL | Visualization of max value | Visualization of the maximum value of every cycle in a simulation | |
/FAIL/WIERZBICKI | Ductile material | Ductile metal | Bao-Xue-Wierzbicki model |
/FAIL/WILKINS | Ductile failure model | Ductile metal | Wilkins model |
Element Compatibility - Part 1
Failure Model | 2D Quad | 8 node Brick | 20 node Brick | 4 node Tetra | 10 node Tetra | 8 node Thick Shell | 16 node Thick Shell |
/FAIL/ALTER | |||||||
/FAIL/BIQUAD | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/CHANG | |||||||
/FAIL/COCKCROFT | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |
/FAIL/CONNECT | ✓ | ||||||
/FAIL/EMC | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/ENERGY | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/FABRIC | |||||||
/FAIL/FLD | |||||||
/FAIL/GENE1 | |||||||
/FAIL/GURSON | ✓ | ✓ | ✓ | ||||
/FAIL/HASHIN | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/HC_DSSE | |||||||
/FAIL/JOHNSON | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/INIEVO | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/LAD_DAMA | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/MULLINS_OR | ✓ | ✓ | ✓ | ✓ | |||
/FAIL/NXT | |||||||
/FAIL/ORTHBIQUAD | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/ORTHSTRAIN | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/PUCK | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/RTCL | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/SAHRAEI | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/SNCONNECT | ✓ | ||||||
/FAIL/SPALLING | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/SYAZWAN | |||||||
/FAIL/TAB1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/TAB2 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/TBUTCHER | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/TENSSTRAIN | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/USERi | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/VISUAL | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/WIERZBICKI | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
/FAIL/WILKINS | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
✓: yes
blank: no
Element Compatibility - Part 2
Failure Model | SHELL | TRUSS | BEAM |
/FAIL/ALTER | ✓ | ||
/FAIL/BIQUAD | ✓ | ||
/FAIL/CHANG | ✓ | ||
/FAIL/COCKCROFT | ✓ | ||
/FAIL/CONNECT | |||
/FAIL/EMC | |||
/FAIL/ENERGY | ✓ | ||
/FAIL/FABRIC | ✓ | ||
/FAIL/FLD | ✓ | ||
/FAIL/GENE1 | |||
/FAIL/GURSON | |||
/FAIL/HASHIN | ✓ | ||
/FAIL/HC_DSSE | ✓ | ||
/FAIL/INIEVO | ✓ | ||
/FAIL/JOHNSON | ✓ | ||
/FAIL/LAD_DAMA | ✓ | ||
/FAIL/MULLINS_OR | |||
/FAIL/NXT | ✓ | ||
/FAIL/ORTHBIQUAD | ✓ | ||
/FAIL/ORTHSTRAIN | ✓ | ||
/FAIL/PUCK | ✓ | ||
/FAIL/RTCL | ✓ | ||
/FAIL/SAHRAEI | |||
/FAIL/SNCONNECT | |||
/FAIL/SPALLING | |||
/FAIL/SYAZWAN | ✓ | ||
/FAIL/TAB1 | ✓ | ||
/FAIL/TAB2 | ✓ | ||
/FAIL/TBUTCHER | ✓ | ||
/FAIL/TENSSTRAIN | ✓ | ||
/FAIL/USERi | ✓ | ||
/FAIL/VISUAL | ✓ | ||
/FAIL/WIERZBICKI | ✓ | ||
/FAIL/WILKINS | ✓ |
✓: yes
blank: no
Law Compatibility with (Metal) Failure Model
Law | ALTER | BIQUAD | COCKCROFT | CONNECT | ECM | ENERGY | FLD | GENE1 | GURSON | HC-DSSE | INIEVO | JOHNSON | NXT | RTCL | SNCONNECT | SPALLING | SYAZWAN | TAB1 | TAB2 | TBUTCHER | TENSSTRAIN | WIERZBICKI | WILKINS |
/MAT/LAW0 (VOID) | ✓ | ✓ | |||||||||||||||||||||
/MAT/PLAS_PREDEF | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | |||||
/MAT/LAW1 (ELAST) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | |||||||||||||||||
/MAT/LAW2 (PLAS_JOHNS) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | |||||
/MAT/PLAS_ZERIL | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | ||||||
/MAT/LAW3 (HYDPLA) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | ||||||||||
/MAT/LAW4 (HYD_JCOOK) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | |||||||||
/MAT/LAW5 (JWL) | |||||||||||||||||||||||
/MAT/LAW6 (HYDRO or HYD_VISC) | ✓ | ✓ | ✓‡ | ||||||||||||||||||||
/MAT/LAW10 (DPRAG1) | ✓ | ✓ | ✓ | ✓‡ | |||||||||||||||||||
/MAT/LAW12 (3D_COMP) | ✓ | ✓ | ✓‡ | ||||||||||||||||||||
/MAT/LAW14 (COMPSO) | ✓ | ✓ | ✓ | ✓‡ | |||||||||||||||||||
/MAT/LAW15 (CHANG) | ✓ | ✓ | ✓ | ||||||||||||||||||||
/MAT/LAW16 (GRAY) | |||||||||||||||||||||||
/MAT/LAW19 (FABRI) | ✓ | ✓ | ✓ | ||||||||||||||||||||
/MAT/LAW21 (DPRAG) | ✓ | ✓ | ✓‡ | ||||||||||||||||||||
/MAT/LAW22 (DAMA) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | ||||||||
/MAT/LAW23 (PLAS_DAMA) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | |||||||||
/MAT/LAW24 (CONC) | ✓ | ✓ | ✓ | ✓‡ | |||||||||||||||||||
/MAT/LAW25 (COMPSH) | ✓ | ✓ | ✓ | ||||||||||||||||||||
/MAT/LAW27 (PLAS_BRIT) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||
/MAT/LAW28 (HONEYCOMB) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||
USER1 | ✓ | ✓* | ✓ | ✓ | ✓ | ||||||||||||||||||
USER2 | ✓ | ✓* | ✓ | ✓ | ✓ | ||||||||||||||||||
USER3 | ✓ | ✓* | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW32 (HILL) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||
/MAT/LAW33 (FOAM_PLAS) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW34 (BOLTZMAN) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW35 (FOAM_VISC) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||
/MAT/LAW36 (PLAS_TAB) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
/MAT/LAW38 (VISC_TAB) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW40 (KELVINMAX) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW41 (LEE_TARVER) | ✓ | ✓ | ✓ | ||||||||||||||||||||
/MAT/LAW42 (OGDEN) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW43 (HILL_TAB) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
/MAT/LAW44 (COWPER) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
/MAT/LAW48 (ZHAO) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW49 (STEINB) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓‡ | ✓ | ✓ | ||||||||
/MAT/LAW50 (VISC_HONEY) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW52 (GURSON) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||
/MAT/LAW53 (TSAI_TAB) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW54 (PREDIT) | ✓ | ||||||||||||||||||||||
/MAT/LAW57 (BARLAT3) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW58 (FABR_A) | ✓ | ✓ | ✓ | ||||||||||||||||||||
/MAT/LAW59 (CONNECT) | ✓ | ✓ | ✓ | ||||||||||||||||||||
/MAT/LAW60 (PLAS_T3) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
/MAT/LAW62 (VISC_HYP) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW63 (HANSEL) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW64 (UGINE_ALZ) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW65 (ELASTOMER) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW66 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW68 (COSSER) | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||||
/MAT/LAW69 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW70 (FOAM_TAB) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW72 (HILL_MMC) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW73 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||
/MAT/LAW74 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||
/MAT/LAW75 (POROUS) | ✓ | ||||||||||||||||||||||
/MAT/LAW76 (SAMP) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||
/MAT/LAW77 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW78 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
/MAT/LAW79 (JOHN_HOLM) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
/MAT/LAW80 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
/MAT/LAW81 | ✓ | ||||||||||||||||||||||
/MAT/LAW82 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW83 | ✓ | ✓ | |||||||||||||||||||||
/MAT/LAW84 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||
/MAT/LAW87 (BARLAT2000) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||
/MAT/LAW88 | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||||
/MAT/LAW90 | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||||
/MAT/LAW92 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||||||||
/MAT/LAW93 (ORTH_HILL) or (CONVERSE) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||||||||||
/MAT/LAW94 (YEOH) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW95 (BERGSTROM_BOYCE) | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW97 (JWLB) | |||||||||||||||||||||||
/MAT/LAW100 (MNF) | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||||
/MAT/LAW101 | ✓ | ✓ | ✓ | ✓ | |||||||||||||||||||
/MAT/LAW102 (DPRAG2) | ✓ | ✓ | ✓ | ✓‡ | |||||||||||||||||||
/MAT/LAW103 (HENSEL-SPITTEL) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||
/MAT/LAW104 (JOHNS_VOCE_DRUCKER) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
/MAT/LAW106 (JCOOK_ALM) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||
/MAT/LAW108 (SPR_GENE) | |||||||||||||||||||||||
/MAT/LAW109 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
/MAT/LAW110 (VEGTER) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
/MAT/LAW111 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||||||||||||||
/MAT/LAW112 (PAPER or XIA) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
/MAT/LAW113 (SPR_BEAM) | |||||||||||||||||||||||
/MAT/LAW114 (SPR_SEATBELT) | |||||||||||||||||||||||
/MAT/LAW115 (DESHFLECK) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
/MAT/LAW116 | |||||||||||||||||||||||
/MAT/LAW117 | |||||||||||||||||||||||
/MAT/LAW119 (SH_SEATBELT) | |||||||||||||||||||||||
/MAT/LAW120 (TAPO) | |||||||||||||||||||||||
/MAT/LAW121 (PLAS_RATE) | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
/MAT/LAW200 (MDS) |
Law Compatibility for Composite and Other Failure Models
✓: yes
blank: no
* : for shells only
** : for solid only
***: LAW1 and /FAIL/LAD_DAMA could only together used as interply material by Plyxfem in /PROP/TYPE17
‡ : flag Istrain (defined in property card) must be activated
- Failure models are not available with global integration (N=0 in /PROP/SHELL) for shells.
- Keyword USER1, USER2 and USER3 refer to /FAIL/USERi for shell and brick elements.
- Up to 6 failure models can be applied to a single material, each failure model representing a failure mode.
- Failure models can be used for SPH simulation for all materials compatible with SPH formulation.
- Four failure models (FLD, JOHNSON, TAB1, and TBUTCHER) are compatible when X-FEM provided property TYPE1 (SHELL), TYPE11 (SH_SANDW), or TYPE51 is used.
- /FAIL/TAB1 and /PROP/TYPE51 cannot be used with XFEM yet.
- FAIL/ORTHSTRAIN is compatible with material or failure which could be used with orthotropic properties.
