/MAT/LAW53 (TSAI_TAB)
Block Format Keyword Describes the law that is a uni-directional orthotropic elasto-plastic law and is only used with solid elements.
/MAT/LAW53/mat_ID/unit_ID or /MAT/TSAI_TAB/mat_ID/unit_ID
mat_title
ρ i
E11 E22
G12 G23
fct_ID11 fct_ID22 fct_ID12 fct_ID23 fct_ID45
Fscale11 Fscale22 Fscale12 Fscale23 Fscale45
Definition
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
E11 Young's modulus
(Real)
[ Pa ]
E22 Young's modulus
(Real)
[ Pa ]
G12 Shear modulus
(Real)
[ Pa ]
G23 Shear modulus
(Real)
[ Pa ]
fct_ID11 Yield stress function identifier in direction 11
(Integer)
fct_ID22 Yield stress function identifier in direction 22
(Integer)
fct_ID12 Yield stress function identifier in direction 12
(Integer)
fct_ID23 Yield stress function identifier in direction 23
(Integer)
fct_ID45 Yield stress function identifier in direction 45
(Integer)
Fscale11 Scale factor for yield function 11
Default = 1.0 (Real)
[ Pa ]
Fscale22 Scale factor for yield function 22
[ Pa ]
Fscale12 Scale factor for yield function 12
[ Pa ]
Fscale23 Scale factor for yield function 23
[ Pa ]
Fscale45 Scale factor for yield function 45
[ Pa ]
Example (Plastic)
#RADIOSS STARTER
/UNIT/1
unit for mat
                 Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW53/1/1
plastic
#              RHO_I
               2E-10
#                E11                 E22
                 200                 200
#                G12                 G23
                 100                 100
# fct_ID11  fct_ID22  fct_ID12  fct_ID23  fct_ID45
         1         1         3         4         5
#           Fscale11            Fscale22            Fscale12            Fscale23            Fscale45
                   0                   0                   0                   0                   0
#-  3. FUNCTIONS:
/FUNCT/1
function_1
#                  X                   Y
                   0                 200
                  .1                 200
                 .11                 100
                  .5                 100
                 1.5               20000
/FUNCT/2
function_2
#                  X                   Y
                   0                   1
               10000                   1
/FUNCT/3
function_3
#                  X                   Y
                   0                 200
                  .1                 200
                 .11                 100
                  .5                 100
                 1.5               20000
/FUNCT/4
function_4
#                  X                   Y
                   0                 200
                  .5                 200
                 1.5               20000
/FUNCT/5
function_5
#                  X                   Y
                   0                 100
                  .5                 100
                 1.5               20000
#ENDDATA
/END
  1. Orthotropic reference frame (1, 2, and 3) is defined in the appropriate property set of each finite element.
    For SOLID property set (/PROP/TYPE14), the global frame is used if Isolid = 1 or 2.
    clip0072
  2. The global frame is ( X MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCiwaaaa@36D7@ , Y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCiwaaaa@36D7@ , and Z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCiwaaaa@36D7@ ).
  3. The local frame is ( t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCiwaaaa@36D7@ , r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCiwaaaa@36D7@ , and s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCiwaaaa@36D7@ ).
    σ 11 = E 11 ε 11 σ 12 = G 12 ε 12
    σ 22 = E 22 ε 22 σ 23 = G 23 ε 23
    σ 33 = E 33 ε 33 σ 13 = G 13 ε 13
  4. The law is othotropic, E33 = E22 and G13 = G12.
  5. The yield surface is Tsai-Wu yield criteria:(1)
    F = F 1 σ 11 + F 2 σ 22 + F 2 σ 33 + F 11 σ 11 2 + F 22 σ 22 2 + F 22 σ 33 2   + F 44 σ 12 2 + F 55 σ 23 2 + F 44 σ 13 2 + 2 F 12 σ 11 σ 22 + 2 F 23 σ 22 σ 33   + 2 F 12 σ 11 σ 33
    with (2)
    F 1 = − 1 σ 1 y c + 1 σ 1 y t ; F 2 = − 1 σ 2 y c + 1 σ 2 y t
    (3)
    F 11 = 1 σ 1 y c σ 1 y t ; F 22 = 1 σ 2 y c σ 2 y t ; F 44 = 1 σ 4 y c σ 4 y t ; F 55 = 1 σ 5 y c σ 5 y t
    (4)
    F 12 = − 1 2 F 11 F 22 ; F 23 = − 1 2 F 22
    The parameters: σ 1 y c , σ 1 y t , σ 2 y c , σ 2 y t , σ 4 y c , σ 4 y t , σ 5 y c , σ 5 y t are variable and introduced by yield function.
  6. If fct_ID45 ≠ 0,(5)
    F 12 = 2 σ 45 y 2 − 1 2 ( F 11 + F 22 + F 44 ) + F 1 + F 2 σ 45 y c
