/MAT/LAW22 (DAMA)
Block Format Keyword This law is identical to Johnson-Cook material (/MAT/LAW2), except that the material undergoes damage if plastic strains reach a user-defined value ( ε d a m ). This law can be applied to both shell and solid elements.
/MAT/LAW22/mat_ID/unit_ID or /MAT/DAMA/mat_ID/unit_ID
mat_title
ρ i
E ν
a b n ε p m a x σ max ​ 0
c ε ˙ 0 ICC
ε d a m Et
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
ν Poisson's ratio.
(Real)
a Yield stress - should be strictly positive.
(Real)
[ Pa ]
b Hardening parameter.
(Real)
[ Pa ]
n Hardening exponent.
(Real)
ε p m a x Failure plastic strain.
Default = 1030 (Real)
σ max ​ 0 Maximum stress.
[ Pa ]
c Strain rate coefficient.
= 0
No strain rate effect
Default = 0.00 (Real)
ε ˙ 0 Reference strain rate.
If ε ˙ ≤ ε ˙ 0 , no strain rate effect.
(Real)
[ 1 s ]
ICC Strain rate computation flag. 2
= 0 (Default)
Set to 1
= 1
Strain rate effect on σ max .
= 2
No strain rate effect on σ max .
(Integer)
ε d a m Damage model starts at ε d a m .
Default = 0.15 (Real)
Et Softening damage slope ( − E < E t ≤ 0 ).
[ Pa ]
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  mm                  ms
#-  2. MATERIALS:
/MAT/DAMA/1/1
Alu
#              RHO_I
               .0027
#                  E                  Nu
               70000                  .3
#                  a                   b                   n             Eps_max          SIGMA_max0
                 100                   0                   1                  .2                 100
#                  c           Eps_dot_0       ICC
                   0                   0         0
#            Eps_dam                 E_t
                  .1               -2000
#ENDDATA
/END
  1. Damage is isotropic, its effect are the same in tension and compression.
    (1)
    σ = ( a + b ε p n ) ( 1 + c ln ε ˙ ε ˙ 0 )
    Where,
    ε p
    Plastic strain
    ε ˙
    Strain rate
  2. ICC is a flag of the strain rate effect on material maximum stress σ max .
    σ = σ y ( 1 + c ln ( ε ˙ ε ˙ o ) ) σ = σ y ( 1 + c ln ( ε ˙ ε ˙ o ) )
    σ max = σ max 0 ( 1 + c ln ( ε ˙ ε ˙ o ) ) σ max = σ max 0
  3. The damage appears in the material when the strain is larger than a maximum value ε d a m :(2)
    0 ≤ δ ≤ 1
    If ε < ε d a m ⇒ δ = 0 , Law 22 is identical to law /MAT/LAW2.
    If ε ≥ ε d a m ⇒ E d a m = ( 1 − δ ) E and ν dam = 1 2 δ+( 1−δ )ν
    clip0053
  4. For solid elements, the damage law can only be applied to the deviatoric stress tensor sij and G d a m = E d a m 2 ( 1 + ν d a m ) .
  5. When ε p reaches ε p m a x in one integration point, then based on the element type:
    • Shell elements: The corresponding shell element is deleted.
    • Solid elements: The deviatoric stress of the corresponding integral point is permanently set to 0, however, the solid element is not deleted.
