/FAIL/WIERZBICKI
Block Format Keyword Describes the BAO-XUE-Wierzbicki failure model.
/FAIL/WIERZBICKI/mat_ID/unit_ID | |||||||||
C1 | C2 | C3 | C4 | m | |||||
n | Ifail_sh | Ifail_so | Imoy |
fail_ID |
Definition
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
C1 | 1st
parameter. (Real) |
C2 | 2nd
parameter. (Real) |
C3 | 3rd
parameter. (Real) |
C4 | 4th
parameter. (Real) |
m | 5th
parameter. (Real) |
n | Hardening
exponent. (Real) |
Ifail_sh | Shell failure model flag.
(Integer) |
Ifail_so | Brick failure model flag.
(Integer) |
Imoy | Failure 3D model
(brick) flag.
(Integer) |
fail_ID | Failure criteria identifier. 2 (Integer, maximum 10 digits) |
Example (Metal)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
#- 1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Metal
# RHO_I
2.8E-9 0
# E Nu
60000 .3
# a b n EPS_p_max SIG_max0
370 190 .4 0 0
# c EPS_DOT_0 ICC Fsmooth F_cut Chard
0 0 0 0 0 0
# m T_melt rhoC_p T_r
0 0 0 0
/FAIL/WIERZBICKI/1/1
# C1 C2 C3 C4 m
0.87 1.77 0.21 0.56 2
# n Ifail_sh Ifail_so Imoy
0.2 0 1 0
#enddata
- For
which is used in failure flag is:
(1)
Figure 1.Where,
For Brick:- If Imoy = 0
- If Imoy = 1
For Shell:- ;
Where,- Hydrostatic stress
- von Mises stress
- Third invariant deviatoric stress
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
