/FAIL/WILKINS
Block Format Keyword Describes the Wilkins failure model.
/FAIL/WILKINS/mat_ID/unit_ID
α β P lim D f Ifail_sh Ifail_so
Optional Line
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
α Hydrostatic pressure exponent.
(Real)
β Deviatoric coefficient.
(Real)
P lim Hydrostatic pressure limit.
(Real)
[ Pa ]
D f Critical damage.
(Real)
Ifail_sh Shell failure flag.
= 1
Shell is deleted, if D c D f for one integration point or layer.
= 2
For each integration point, the stress tensor is set to zero, if D c D f and shell is deleted, if D c D f for all integration points or layers.
(Integer)
Ifail_so Solid failure flag.
= 1
Solid is deleted, if D c D f for one integration point.
= 2
For each integration point, the deviatoric stress tensor vanishes, if D c D f .
(Integer)
fail_ID Failure criteria identifier. 2
Example (Metal)
#RADIOSS STARTER
/UNIT/1
unit for mat
#              MUNIT               LUNIT               TUNIT
                  Mg                  mm                   s
#-  1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Metal
#              RHO_I
              2.8E-9                   0
#                  E                  Nu
               60000                  .3
#                  a                   b                   n           EPS_p_max            SIG_max0
                 370                 190                  .4                   0                   0
#                  c           EPS_DOT_0       ICC   Fsmooth               F_cut               Chard
                   0                   0         0         0                   0                   0
#                  m              T_melt              rhoC_p                 T_r
                   0                   0                   0                   0
/FAIL/WILKINS/1/1
#              Alpha                Beta                Plim                  Df  Ifail_sh  Ifail_so
                 1.8                 .75                 750                 0.3         1         0
#enddata
  1. The cumulative damage is:
    D c = W 1 W 2 d ε ¯ p
    Where,
    W 1 = ( 1 1 + a P ) α
    a = 1 P lim
    Where,
    P
    Hydro pressure
    P = 1 3 j = 1 3 σ j j
    W 2 = ( 2 A ) β
    A = max ( s 2 s 1 , s 2 s 3 ) , s 1 s 2 s 3
    Where, s 1 , s 2 , s 3 are the deviatoric stresses.
  2. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
