/MAT/LAW92
Block Format Keyword This law describes the Arruda-Boyce material model, which can be used to model hyperelastic behavior.
A stress versus strain curve can be defined as an input function in order to determine the material parameters by fitting this curve. This law is only compatible with solid elements.
/MAT/LAW92/mat_ID/unit_ID
mat_title
ρ i
Parameter input
μ D λ m
Function input
Itype fct_ID ν Fscale
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
μ Shear modulus.
Used only if fct_ID is not defined.
(Real)
[ Pa ]
D Material parameter.
If null, D is automatically computed from μ , λ m and ν =0.495. 2
(Real)
[ 1 P a ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWadaqaam aalaaabaGaaGymaaqaaiaaccfacaGGHbaaaaGaay5waiaaw2faaaaa @3AD5@
λ m The limit of stretch.
Default = 7.0 (Real)
Itype Test data type (stress strain curve).
= 1 (Default)
Uniaxial data test
= 2
Equibiaxial data test
= 3
Planar data test
(Integer)
fct_ID Function identifier defining engineer stress versus engineer strain.
(Integer)
ν Poisson's ratio.
Used only if fct_ID is defined.
Default = 0.495 (Real)
Fscale Scale factor for ordinate (stress) in function fct_ID.
Default = 1.0 (Real)
[ Pa ]
Example (Rubber with Parameter Input)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW92/1/1
Generic RUBBER
#              RHO_I
            1.000E-9
#                 mu                   D                 LAM
          2.8000E+01           1.4000E-1               1000.
#    IType    fct_ID                  NU              Fscale
#ENDDATA
/END
Example (Rubber with Function Input)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW92/1/1
rubber
#              RHO_I
            1.000E-9
#                 mu                   D                 LAM
         1         2               0.495
/FUNCT/2
LAW92  e.strain vs  e.stress from uniaxial test(IType=1)
#                  X                   Y
                   0                   0
                 .03                 .30
                 .06                 .55
                 .10                 .80
                 .20                 1.4
                 .30                 2.0
                 .50                 2.7
                 .70                 3.4
                 1.0                 4.0
#ENDDATA
/END
  1. The Arruda-Boyce energy density.(1)
    W=μ i=1 5 c i ( λ m ) 2i2 ( I ¯ 1 i 3 i )+ 1 D ( J 2 1 2 ln(J) ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbGaey ypa0JaeqiVd02aaabCaeaadaWcaaqaaiaadogadaWgaaWcbaGaamyA aaqabaaakeaacaGGOaGaeq4UdW2aaSbaaSqaaiaad2gaaeqaaOGaai ykamaaCaaaleqabaGaaGOmaiaadMgacqGHsislcaaIYaaaaaaaaeaa caWGPbGaeyypa0JaaGymaaqaaiaaiwdaa0GaeyyeIuoakmaabmaaba GabmysayaaraWaa0baaSqaaiaaigdaaeaacaWGPbaaaOGaeyOeI0Ia aG4mamaaCaaaleqabaGaamyAaaaaaOGaayjkaiaawMcaaiabgUcaRm aalaaabaGaaGymaaqaaiaadseaaaWaaeWaaeaadaWcaaqaaiaadQea daahaaWcbeqaaiaaikdaaaGccqGHsislcaaIXaaabaGaaGOmaaaacq GHsislciGGSbGaaiOBaiGacIcacaWGkbGaaiykaaGaayjkaiaawMca aaaa@5DC5@
    With(2)
    c 1 = 1 2 , c 2 = 1 20 , c 3 = 11 1050 , c 4 = 19 7000 , c 5 = 519 673750
    and (3)
    I ¯ 1 = λ ¯ 1 2 + λ ¯ 2 2 + λ ¯ 3 2
    with λ ¯ k = J 1 / 3 λ J = λ 1 λ 2 λ 3
    The Cauchy stress is computed as:(4)
    σ i = λ i J W λ i
  2. If the stress strain curve, fct_ID is not defined, the material parameters in line 3, μ , D MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraaaa@369F@ and λ m must be defined and the line 4 input is not used.
    Ground shear modulus is computed as:(5)
    μ 0 = μ ( 1 + 3 5 ( 1 λ m 2 ) + 99 175 ( 1 λ m 4 ) + 513 875 ( 1 λ m 6 ) + 42039 67375 ( 1 λ m 8 ) ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd02aaS baaSqaaiaaicdaaeqaaOGaeyypa0JaeqiVd02aaeWaaeaacaaIXaGa ey4kaSYaaSaaaeaacaaIZaaabaGaaGynaaaadaqadaqaamaalaaaba GaaGymaaqaaiabeU7aSnaaDaaaleaacaWGTbaabaGaaGOmaaaaaaaa kiaawIcacaGLPaaacqGHRaWkdaWcaaqaaiaaiMdacaaI5aaabaGaaG ymaiaaiEdacaaI1aaaamaabmaabaWaaSaaaeaacaaIXaaabaGaeq4U dW2aa0baaSqaaiaad2gaaeaacaaI0aaaaaaaaOGaayjkaiaawMcaai abgUcaRmaalaaabaGaaGynaiaaigdacaaIZaaabaGaaGioaiaaiEda caaI1aaaamaabmaabaWaaSaaaeaacaaIXaaabaGaeq4UdW2aa0baaS qaaiaad2gaaeaacaaI2aaaaaaaaOGaayjkaiaawMcaaiabgUcaRmaa laaabaGaaGinaiaaikdacaaIWaGaaG4maiaaiMdaaeaacaaI2aGaaG 4naiaaiodacaaI3aGaaGynaaaadaqadaqaamaalaaabaGaaGymaaqa aiabeU7aSnaaDaaaleaacaWGTbaabaGaaGioaaaaaaaakiaawIcaca GLPaaaaiaawIcacaGLPaaaaaa@6A4C@
    If D MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraaaa@369F@ is not defined, the bulk modulus is calculated as:(6)
    K = 2 ( 1 + υ ) μ 0 3 ( 1 2 υ ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saiabg2 da9maalaaabaGaaGOmaiaacIcacaaIXaGaey4kaSIaeqyXduNaaiyk aiabeY7aTnaaBaaaleaacaaIWaaabeaaaOqaaiaaiodadaqadaqaai aaigdacqGHsislcaaIYaGaeqyXduhacaGLOaGaayzkaaaaaaaa@466D@
    Where, υ = 0.495 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXduNaey ypa0JaaGimaiaac6cacaaI0aGaaGyoaiaaiwdaaaa@3C70@ and D = 2 K MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maalaaabaGaaGOmaaqaaiaadUeaaaaaaa@3962@ .
    If D MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraaaa@369F@ is defined, the formula should be K = 2 D MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saiabg2 da9maalaaabaGaaGOmaaqaaiaadseaaaaaaa@3962@ , and the Poisson ratio is updated with υ = 3 K 2 μ 0 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXduNaey ypa0ZaaSaaaeaacaaIZaGaam4saiabgkHiTiaaikdacqaH8oqBdaWg aaWcbaGaaGimaaqabaaakeaacaaIZaaaaaaa@3F6C@ .
    Note: For positive values of shear modulus, μ , and Limit of stretch, λ m , this model is always stable.
  3. If the stress strain curve, fct_ID, is defined then the line 3 input parameters μ , D MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraaaa@369F@ and λ m are ignored and are automatically identified by fitting of the provided stress versus strain curve.
    A nonlinear least squares algorithm is used to fit the Arruda-Boyce parameters. The model is fully incompressible in fitting the Arruda-Boyce constants to the test data, except in the volumetric test.(7)
    E = k = 1 n d a t a ( N k t e s t N k t h N k t e s t ) 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGfbGaey ypa0ZaaabCaeaadaqadaqaamaalaaabaGaamOtamaaDaaaleaacaWG RbaabaGaamiDaiaadwgacaWGZbGaamiDaaaakiabgkHiTiaad6eada qhaaWcbaGaam4AaaqaaiaadshacaWGObaaaaGcbaGaamOtamaaDaaa leaacaWGRbaabaGaamiDaiaadwgacaWGZbGaamiDaaaaaaaakiaawI cacaGLPaaaaSqaaiaadUgacqGH9aqpcaaIXaaabaGaamOBaiaadsga caWGHbGaamiDaiaadggaa0GaeyyeIuoakmaaCaaaleqabaGaaGOmaa aaaaa@54B8@
    Where E is relative error. The material constants are obtained using a least-squares-fit procedure to minimize the relative error between the theoretical nominal stress and given experimental data.(8)
    λ 1 = λ 2 = λ and λ 3 = λ 2 with λ = 1 + ε
    Where, N k test is a stress value from the test data and N i th is the theoretical nominal stress given by for each engineer strain i.(9)
    N k t h = W λ k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGobWaa0 baaSqaaiaadUgaaeaacaWG0bGaamiAaaaakiabg2da9maalaaabaGa eyOaIyRaam4vaaqaaiabgkGi2kabeU7aSnaaBaaaleaacaWGRbaabe aaaaaaaa@41CD@
    The nominal stress is computed for each mode assuming the full incompressibility:(10)
    J = λ 1 λ 2 λ 3 = 1
    • Uniaxial Mode:
      (11)
      λ 1 = λ and λ 2 = λ 3 = λ 1 2 with λ = 1 + ε
      So(12)
      N th = W λ = 2 μ ( λ λ 2 ) i = 1 5 ic i ( λ m ) 2 i 2 I ¯ 1 i 1 with I ¯ 1 = λ 2 + 2 λ
    • Equibiaxial Mode:
      (13)
      So(14)
      N th = W λ = 2 μ ( λ λ 5 ) i = 1 5 ic i ( λ m ) 2 i 2 I ¯ 1 i 1 with I ¯ 1 = 2 λ 2 + 1 λ 4
    • Planar (Shear Mode):
      (15)
      λ 1 = λ , λ 3 = 1 and λ 2 = λ 1 with λ = 1 + ε MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH7oaBda WgaaWcbaGaaGymaaqabaGccqGH9aqpcqaH7oaBcaaMe8Uaaiilaiaa ysW7cqaH7oaBdaWgaaWcbaGaaG4maaqabaGccqGH9aqpcaaIXaGaaG zbVlaabggacaqGUbGaaeizaiaaywW7cqaH7oaBdaWgaaWcbaGaaGOm aaqabaGccqGH9aqpcqaH7oaBdaahaaWcbeqaaiabgkHiTiaaigdaaa GccaaMb8UaaGzbVlaabEhacaqGPbGaaeiDaiaabIgacaaMf8Uaeq4U dWMaeyypa0JaaGymaiabgUcaRiabew7aLbaa@5F73@
      So (16)
      N th = W λ = 2 μ ( λ λ 3 ) i = 1 5 ic i ( λ m ) 2 i 2 I ¯ 1 i 1 with I ¯ 1 = λ 2 + 1 + λ 2
  4. /VISC/PRONY must be used with LAW92 to include viscous effects.
