/PROP/TYPE19 (PLY)
Block Format Keyword This property set is used to define the ply property set used in ply-based composite definition. It is used in combination with /PROP/STACK (/PROP/TYPE17) or /PROP/TYPE51 to create ply-based sandwich composite properties.
/PROP/TYPE19/prop_ID/unit_ID or /PROP/PLY/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
mat_ID | t | grsh4n_ID | grsh3n_ID | Npt_ply |
drape_ID | def_orth |
Definition
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property
mat_ID | Material identifier for
ply (Integer) |
t | Thickness of
ply (Real) |
Incremental angle for ply.
4
(Real) |
grsh4n_ID | Shell 4-nodes group
identifier connected to ply. 2 (Integer) |
grsh3n_ID | Shell 3-nodes group
identifier connected to ply. (Integer) |
Npt_ply | Number of integration
points through ply thickness with, Npt_ply=1, for /PROP/TYPE17 (STACK). 1 ≤ Npt_ply≤10, for /PROP/TYPE51. = 1 (Default) (Integer) |
Angle between first and
second material direction for ply i. Default = 90.0 (Real) |
drape_ID | Drape identification number. 3 (Integer) |
def_orth | The orthotropy angle.
#RADIOSS STARTER
/UNIT/2
unit for prop
# MUNIT LUNIT TUNIT
kg mm ms
/PROP/TYPE19/11/2
PROP number 11
# mat_ID_i t delta_phi id_grsh4n id_grsh3n Npt_ply A_i
1 .5 45 0 0 0 0
#enddata
- This ply property is used in combination with /PROP/TYPE17 (STACK) or /PROP/TYPE51 to create ply-based sandwich composite properties. The compatibility to material law of this option is depend on its combination of /PROP/TYPE17 (STACK) and /PROP/TYPE51.
- If both grsh4n_ID =0 and grsh3n_ID = 0, all elements in the part that reference this property belong to the ply.
- The orthotropy angle in
ply:
- Orthotropy angle defined without def_orth and
drape_ID in optional lineThe angle for ply i (in /PROP/STACK):
(1) Where,- Defined in the /PROP/STACK
- Orthotropy angle defined with def_orth and
- If def_orth = 2, the angle between the
reference direction and the first direction of orthotropy
is:
(2) Where,- Angle increment defined in the drape option drape_ID (if any)
- Defined in the /PROP/STACK for the ply.
- If def_orth = 1, the angle between the shell
skew and the first direction of orthotropy is:Where,
- Defined in the shell (/SHELL or /SH3N).
If def_orth = 1, Iskew, VX, VY, and VZ from the /PROP/STACK and /PROP/TYPE51 input are ignored.
is:
- If
drape_ID is defined in optional line, the angle of each
element defined in the drape is incremented by /DRAPE,
and the thickness is modified by the ply thinning factor /DRAPE, Thinning.
