/PROP/TYPE1 (SHELL)
Block Format Keyword Describes the shell property set which is used for 3-node or 4-node shell element. Belytschko, QBAT or QEPH shell formulation are available.
/PROP/TYPE1/prop_ID/unit_ID or /PROP/SHELL/prop_ID/unit_ID
prop_title
Ishell Ismstr Ish3n Idril Ipinch   P_thickfail
hm hf hr dm dn
N   Thick Ashear   Ithick Iplas
Definition
prop_ID Property identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
prop_title Property title.
Ishell 4 node shell element formulation flag.
= 0
Use value in /DEF_SHELL.
= 1 Default, if /DEF_SHELL is not defined
Q4, visco-elastic hourglass modes orthogonal to deformation and rigid modes (Belytschko).
= 2
Q4, visco-elastic hourglass without orthogonality (Hallquist).
= 3
Q4, elasto-plastic hourglass with orthogonality.
= 4
Q4 with improved type 1 formulation (orthogonalization for warped elements).
= 12
QBAT shell formulation.
= 24
QEPH shell formulation.
(Integer)
Ismstr Shell small strain formulation flag. 4
= -1
Automatically set the best value according to element type and material law.
= 0
= 1
Small strain from time = 0 (formulation compatible with all other formulation flags).
= 2 Default, if /DEF_SHELL is not defined
Full geometric nonlinearities with possible small strain formulation activation in Radioss Engine (option /DT/SHELL/CST).
= 3
Old small strain formulation (only compatible with Ishell = 2).
= 4
Full geometric nonlinearities (in Radioss Engine, option /DT/SHELL/CST has no effect).
= 10
Lagrange type total strain for hyperelastic material laws.
(Integer)
Ish3n 3 node shell element formulation flag.
= 0
= 1
Standard triangle (C0).
Standard triangle (C0) with modification for large rotation.
= 30
DKT18.
= 31
DKT_S3, which based on DTK12 of BATOZ (refer to the Element Library in the Theory Manual).
(Integer)
Idril Drilling degree of freedom stiffness flag. 3
= 0
= 1
Yes.
No.
(Integer)
Ipinch Pinching degree of freedom flag. 12
= 0
Disable
= 1
Enable
(Integer)
P_thickfail Ratio of through thickness integration points that must fail before the element is deleted. 11
0.0 P _ t h i c k f a i l 1.0
(Real)
hm Shell membrane hourglass coefficient. 5
Only used when Ishell=1, 2, 3, 4.
Default = 0.01 for Ishell =1, 2, 4.
Default = 0.1 for Ishell = 3.
(Real)
hf Shell out-of-plane hourglass. 5
Default = 0.01 (Real)
hr Shell rotation hourglass coefficient. 5
(Real)
dm Shell Membrane Damping
For default values, refer to the table in Comment 7.
(Real)
dn Shell numerical damping. 6
It is only used for Ishell =12, 24 and Ish3n = 30
Default =0.015 for Ishell =24 (QEPH)
Default =0.001 for Ishell =12 (QBAT)
Default =0.0001 for Ish3n =30 (DKT18)
(Real)
N Number of integration points through the thickness with 0 < N < 10. 10
= 0 (Default)
Means global integration model for material LAW1, and automatically set N=3 for other material laws.
= 1
Membrane behavior.
(Integer)
Thick Shell thickness.
(Real)
[ m ]
Ashear Shear factor.
Default is Reissner value: 5/6 (Real)
Ithick Shell resultant stresses calculation flag. 8
= -1
= 0
= 1
Thickness change is taken into account.
Thickness is constant.
(Integer)
Iplas Shell plane stress plasticity flag. 9
It is available for material laws 2, 22, 27 and 36.
= -1
= 0
= 1 Default for LAW36 and global integration.
Iterative projection with three Newton iterations.
= 2 Default, if /DEF_SHELL is not defined or for LAW2 and global integration
Radial return.
(Integer)
  1. Ishell - Shell small strain formulation flag
    • Ishell=1,2,3,4 (Q4): original 4 node Radioss shell with hourglass perturbation stabilization
    • Ishell=24 (QEPH): formulation with hourglass physical stabilization for general use
    • Ishell=12 (QBAT): modified BATOZ Q4γ24 shell with four Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell
    • Ishell=2 is incompatible with one integration point (through thickness) for shell element
  2. Ish3n - 3 node shell element formulation flag
    • Ish3n=30 (DKT18): BATOZ DKT18 thin shell with three Hammer integration points
  3. Idril - Drilling degree of freedom stiffness flag
    • Drilling DOF stiffness is recommended for implicit solutions especially for Riks method and bending dominated problems
    • Idril is available for QEPH, QBAT (Ishell =12, 24), and standard triangle (C0) shell elements (Ish3n = 1, 2)
  4. Ismstr - Small strain formulation
    • Small strain formulation is activated from time t=0, if Ismstr =1 or 3. It may be used for a faster preliminary analysis, but the accuracy of the results is not ensured.
    • Any shell for which Δt < Δt min MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaqGuoGaae iDaiaayIW7caqG8aGaaGjcVlaabs5acaqG0bWaaSbaaSqaaiaab2ga caqGPbGaaeOBaaqabaaaaa@415B@ can be switched to a small strain formulation by Radioss Engine option /DT/SHELL/CST; except if Ismstr =4.
    • If the small strain option is set to 1 or 3, the strains and stresses which are given in material laws, are engineering strains and stresses; otherwise they are true strains and stresses.
    • Ismstr =10 is only compatible with these material laws 42, 62, 69, and 82 that use total strain formulation. Generally, the Left Cauchy-Green strain is used. For User laws, the deformation gradient tensor and the right stretch tensor may be used.
  5. hm, hf, and hr - Hourglass coefficients
    • Are only used for Q4 shells (Ishell=1,2,3,4). They must have a value between 0 and 0.05.
    • For Ishell=3, the default values of hm and hr are 0.1 with larger values possible.
  6. dn - Shell numerical damping coefficient
    • dn is only used for Ishell =12, 24 and Ish3n = 30
      • Ishell =24 (QEPH) dn is used for hourglass stress calculation
      • Ishell =12 (QBAT) dn is used for all stress terms, except transvers shear
      • Ish3n =30 (DKT18) dn is only used for membrane
  7. Default value for numerical damping coefficient dm.
      dm
    Ishell= 1, 2, 3, 4 (Q4) 0.05 for LAW27
    0.0 for LAW32, 36
    Ishell=12 (QBAT) 0.0 for LAW2, 27, 32, 36
    Ishell=24 (QEPH) 0.015 for all other material
    Ish3n= 1, 2, 31 0.0
    Ish3n=30 (DKT18) 0.0
    Any Ishell, Ish3n 0.05 for LAW65
  8. Ithick - Shell resultant stresses calculation flag
    • Ithick is automatically set to 1 for material LAW32
    • Ithick =1, the small strain option is automatically deactivated in the corresponding type of element
  9. Iplas - Shell plane stress plasticity flag
    • It is recommended to use Iplas =1, if Ithick =1
    • If Iplas =1, the small strain option is automatically deactivated in the corresponding type of element
  10. Global integration, N=0
    • Global integration is only compatible with material LAW1.
    • Failure models are not available with global integration for shells.
    • State files (/STATE/DT which creates /INISHE and /INISH3N) are not compatible with global integration.
    • Automatically set to N=3 for the other material laws.
  11. Element deletion rules used with /FAIL models.
    • Under-integrated elements (Belytschko, QEPH, DKT18):
      • If only one /FAIL model with its own P_thickfail (/FAIL/BIQUAD, /FAIL/TAB1) is applied to the shell material, and P_thickfail on the /FAIL card is set > 0, the value of P_thickfail is used regardless of P_thickfail set on the /PROP/SHELL card. If the value of P_thickfail on the /FAIL card is set at 0, the P_thickfail from the property card is used (no default value, so should be set to > 0 to avoid rupture after single integration point failure if that is not desired).
      • If only one /FAIL model without its own P_thickfail (/FAIL/JOHNSON) is applied to the shell material, and the P_thickfail value from the /PROP/SHELL property is set to > 0, the property P_thickfail is taken by default and overwrites Ifail_sh settings from the failure model. If P_thickfail on the property is set = 0 (or blank), then Ifail_sh from the failure model is used (for legacy compatibility).
      • If more than one /FAIL failure model is applied to the shell material, the value of P_thickfail is calculated individually from each of the failure model P_thickfail or Ifail_sh settings and P_thickfail on the property card is ignored.
        For Example, per failure model:
        • If Ifail_sh = 1 (one integration point failure sufficient to delete element) = P_thickfail= 1.0 e-6
        • If Ifail_sh = 2 (all integration points failure is necessary to delete the element) = P_thickfail = 1.0
        • If P_thickfail (/FAIL) = 0, = P_thickfail = 0.0
          In this case on a /FAIL card with P_thickfail, failure will occur when a single integration point fails, due to this /FAIL (set to > 0 if this is not desired).
    • Fully-integrated shells (Batoz, DKT_S3)
      The rule described for under-integrated shells applies to each Gauss point separately. P_thickfail ratio is checked for all integration points in thickness for each in-plane Gauss point. The element is deleted only when all Gauss points reach P_thickfail ratio criteria.
  12. Ipinch is used to enable or disable set pinching degree of freedom. Currently, only supported for QBAT shells (Ishell=12).
