RD-E: 2600 Ruptured Plate
A metallic thick plate is perforated by a rigid sphere. Simulation of the rupture uses different failure models.
![ex_26_rup_plate](../../../images/solvers/ex_26_rup_plate.png)
- Rupture using a damage model in LAW27
- Failure using the Johnson-Cook model
- Advantage of Forming Limit Diagram as a failure model
The sensitivity of the results for the different failure models is demonstrated.
