RD-E: 5200 Creep and Stress Relaxation
The purpose of this example is to introduce how to use typical visco-elastic material to simulate creep and stress relaxation tests.
Stress relaxation is the phenomena of how polymers relieve stress under constant strain, and creep is the phenomena of how polymers or metal move slowly or deform permanently under constant stresses. This simulates the creep and relaxation processes over a short period of time in quasi-static. Use visco-elastic material law /MAT/LAW40 to simulate the creep and stress relaxation.
ex_52_creep_stress
Options and Keywords Used
Input Files
Before you begin, copy the file(s) used in this example to your working directory.
Model Description
A foam sample with dimension: Radius 10 mm and high 15 mm.
  • For stress relaxation test: The foam sample has been compressed until a given strain and kept in this state.
  • For creep test: The foam sample has been tensile under constant force.
ex_52_creep_stress
Figure 2. Problem Description
Units: mm, s, Mg, N, MPa
To describe the phenomenon stress relaxation and creep, use viscous material law /MAT/LAW40 with the following characteristics of foam:
Material Properties
Initial density
2e-9 [Mg/mm3]
Bulk modulus
66.67 [ MPa ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWadaqaai Gac2eacaGGqbGaaiyyaaGaay5waiaaw2faaaaa@3BE6@
Long time shear modulus Ginf
10 [ MPa ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWadaqaai Gac2eacaGGqbGaaiyyaaGaay5waiaaw2faaaaa@3BE6@
Shear modulus G1
90 [ MPa ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWadaqaai Gac2eacaGGqbGaaiyyaaGaay5waiaaw2faaaaa@3BE6@
Decay constant
β 1 = 0.01 [1/ms]
β 2 = 0.05 [1/ms]
β 1 = 1 [1/ms] for compare
Model Method
ex_52_creep_test
Figure 3. Stress Relaxation Test under Constant Displacement and Creep Test under Constant Force
For stress relaxation test: The foam sample has been compressed under constant displacement (/IMPDISP).
For creep test: The foam sample has been tensile under constant force (/CLOAD).
Results
The stress relaxation test shows stress relieve under constant displacement with different relaxation parameters (Decay constant, β defined as the inverse of relaxation time τ ) and β shows a different stress relive tendency.
ex_52_stress
Figure 4.
ex_52_stress2
Figure 5. Stress Relieved with Different Decay Constant β in Stress Relaxation Test under Constant Displacement
The creep test shows deformation increased under constant force and with different relaxation parameter β it shows a different deformation increase tendency.
ex_52_sample
Figure 6.
ex_52_sample2
Figure 7. Sample Deformed with Decay Constant β in Creep Test under Constant Force
In LAW40 shear modulus is reduced with time and tends to G∞ after an infinite period of time. The softening speed is determined by relaxation parameter β . Higher relaxation parameter means quick softening.(1)
mat40_relax_time with ex_52_ti
The general case of viscous materials represents time-dependent in elastic behavior. Creep is time-depended deformation and stress relaxation is a time-depended decrease in stress. Viscous material can describe these two phenomenons. In Radioss, the following material laws describe viscous:
Visco-elastic Law
/MAT/LAW34
Visco-elastic generalized Maxwell model, Boltzmann (solids)
/MAT/LAW35
Visco-elastic generalized Maxwell-Kelvin-Voigt (shells + solids)
/MAT/LAW38
Visco-elastic tabulated (solids)
/MAT/LAW40
Visco-elastic generalized Maxwell-Kelvin (solids)
/MAT/LAW42
Ogden/Mooney-Rivlin with Prony viscosity (Hyperelastic materials)
/MAT/LAW62
Ogden (Hyperelastic materials)
/MAT/LAW70
/MAT/LAW77
Visco-elastic tabulated with porosity and air flow
Visco-elastic Plastic Law
/MAT/LAW33
Visco-elastic plastic (solids) and user-defined yield function
/MAT/LAW52
Gurson, visco-elasto-plastic porous metals, and strain rate dependent
/MAT/LAW66
Semi-analytical plastic model. Yield surface built from curves in tension, compression and shear + /VISC/PRONY
The creep compliance and the relaxation modulus are often modeled by combinations of springs and dashpots. The two typical simple schematic model of visco-elastic material are Maxwell model and Kelvin-Voigt model. The Maxwell model represents the material relaxation, but it is only accurate for secondary creep (creep with slow decrease in creep strain rate) as the viscous strains after unloading are not taken into account. The plasticity can be introduced in the models by using a plastic spring. Based on the Maxwell and Kelvin-Voigt models adding other springs could get a generalized model. The Maxwell and Kelvin-Voigt models are appropriate for ideal stress relaxation and creep behaviors. Although, they are not adequate for most of physical materials. A generalization of these laws, like LAW34, LAW35 and LAW40 are a better choice, which can describe deviatory behavior of material.
ex_52_maxwell_model
Figure 8. Maxwell Model
ex_52_kelvin_voigt_model
Figure 9. Kelvin_Voigt Model
