RD-E: 4600 TNT Cylinder Expansion Test
An experimental test used to characterize the adiabatic expansion of detonation products. It allows JWL EOS parameters to be determined.
- Axisymmetric mesh of a cylinder with four node quad elements (for Lagrangian Approach)
- 3D mesh of a quarter-cylinder with eight node brick elements (for Eulerian Approach)
- Jones-Wilkins-Lee Equation-of-State for TNT detonation products (/MAT/JWL)
- Hydrodynamic Johnson-Cook material law for the copper cylinder (/MAT/HYD_JCOOK)
- Multi-Material, Fluid and Explosive material law (/MAT/LAW51)
The simulation results are then compared to the experiment data.
